[GRASS-user] Grass GUI does not start (anymore) in MacOs
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Mar 27 10:27:52 EDT 2012
Ah well, I guess it will remain a mystery.  I'll add something to the readme...
On Mar 27, 2012, at 9:09 AM, Julian Bogdani wrote:
> Yes,
> I have in Terminal > Settings > Advanced:
> Character encoding Unicode (UTF-8)
> and "Set locale environment variables on startup" checked
> Julian
> http://bradypus.net
> On 27 Mar 2012, at 16:05 , William Kyngesburye wrote:
>> That's not it then.  10.6.8 here also.
>> Did you try turning on the Terminal pref to set the locale?
>> On Mar 27, 2012, at 8:50 AM, Julian Bogdani wrote:
>>> Mine is 10.6.8
>>> Julian
>>> http://bradypus.net
>>> On 27 Mar 2012, at 15:47 , William Kyngesburye wrote:
>>>> Huh.  Well, I did some poking around on the 'net and it looks like it's a bug in OS X 10.6 Terminal (LC_CTYPE=UTF-8 is wrong).  But it's working for me - maybe it was fixed in an update - what is your system version?
>>>> On Mar 27, 2012, at 8:27 AM, Julian Bogdani wrote:
>>>>> Hello and thank you for the help.
>>>>> I have an English system and checking with env I had correctly LC_CTYPE=UTF-8.
>>>>> Terminal preferences was correctly set.
>>>>> Adding export LC_ALL=en_US.UTF-8 did solve the problem.
>>>>> Thank you
>>>>> Julian
>>>>> http://bradypus.net
>>>>> On 27 Mar 2012, at 15:16 , William Kyngesburye wrote:
>>>>>> I forgot to add a bash_profile example:
>>>>>> substitute your language code for en_US.
>>>>>> On Mar 27, 2012, at 8:11 AM, William Kyngesburye wrote:
>>>>>>> Hmm, this is becoming quite an issue on non-English systems, I don't know why it started.  Python expects the locale to be in the form language.encoding.  ie english is "en_US.UTF-8".
>>>>>>> Normally the option in the Terminal to set this automatically takes care of this in the LANG variable, but Python checks LC_CTYPE and LC_ALL first and somehow one of those is getting set on non-english systems.
>>>>>>> The fix is to set LC_ALL in your ~/.bash_profile like LANG is set for your language (turn on the "Set locale env variables on startup" option in the advanced Settings in Terminal Preferences, then check "env" in a Terminal).
>>>>>>> Note: the Adobe Unit Types error is harmless noise, you just have a very old Photoshop installed.
>>>>>>> On Mar 27, 2012, at 2:55 AM, jbogdani wrote:
>>>>>>>> Hello,
>>>>>>>> I've a problem with GRASS on Snow Leopard. I've used successfully GRASS in
>>>>>>>> the past, but it does not start in the GUI mode anymore. I can use it throw
>>>>>>>> QGIS anyway.
>>>>>>>> Here is the error it produces on stratup:
>>>>>>>> 2012-03-27 09:52:23.326 osascript[534:903] Error loading
>>>>>>>> /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit
>>>>>>>> Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit
>>>>>>>> Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.
>>>>>>>> Did find:
>>>>>>>> Types: no matching architecture in universal wrapper
>>>>>>>> osascript: OpenScripting.framework - scripting addition
>>>>>>>> "/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no loadable
>>>>>>>> handlers.
>>>>>>>> Python 2.6.1 found.
>>>>>>>> And then, after hitting RETURN:
>>>>>>>> Traceback (most recent call last):
>>>>>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>>>>>>>> line 894, in <module>
>>>>>>>> GRASSStartUp = StartUp(0)
>>>>>>>> File
>>>>>>>> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>>>>>>> line 7981, in __init__
>>>>>>>> File
>>>>>>>> line 7555, in _BootstrapApp
>>>>>>>> line 865, in OnInit
>>>>>>>> StartUp = GRASSStartup()
>>>>>>>> line 57, in __init__
>>>>>>>> self.grassrc  = self._readGisRC()
>>>>>>>> line 393, in _readGisRC
>>>>>>>> grassrc[key.strip()] = utils.DecodeString(val.strip())
>>>>>>>> File
>>>>>>>> "/Users/Shared/src/GRASS/grass-6.4.2-snow/dist.i386-apple-darwin11.3.0/etc/wxpython/gui_modules/utils.py",
>>>>>>>> line 667, in DecodeString
>>>>>>>> File
>>>>>>>> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
>>>>>>>> line 459, in getdefaultlocale
>>>>>>>> return _parse_localename(localename)
>>>>>>>> File
>>>>>>>> line 391, in _parse_localename
>>>>>>>> raise ValueError, 'unknown locale: %s' % localename
>>>>>>>> ValueError: unknown locale: UTF-8
>>>>>>>> Error in GUI startup. If necessary, please
>>>>>>>> report this error to the GRASS developers.
>>>>>>>> Switching to text mode now.
>>>>>>>> Hit RETURN to continue...
>>>>>>>> After this I can use GRASS only from terminal....
>>>>>>>> Any help?
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
>>>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
>> "Don't you even hate 'em?"
>> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
>> <Ha, ha> "And it might give 'em all stomach ulcers."
>> - Tarzan, on war
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
