[GRASS-user] How to retrieve raster pixel value over a vector point layer
Helena Herrera helenaherrera1980 at gmail.com
Thu Mar 29 08:35:59 EDT 2012
Hi
I was thinking in something much simpler like just printing Pixel values
next to Point ID.
I will give a try on your suggestions.
Thanks
2012/3/28 Micha Silver <micha at arava.co.il>
>  On 03/28/2012 08:11 PM, Helena Herrera wrote:
> Greetings
> I have a raster layer and a vector point layer and I need to associate
> pixel values with points:
> When you say "associate" If you mean to add the raster values to a column
> in the point vector attribute table, then v.what.rast is what you're
> looking for.
>  1- pixel values that are over points;
> 2- 3x3 pixel neighbor pixel values over a point.
> Create a new raster with r.neighbors then run v.what.rast again to upload
> these 3x3 neighborhood values to another column in the point vector.
>  Is this possible do to in a more automatic way than query each by each
> point?
> Here are the steps:
> v.db.addcol vector_map col="rast_val double, rast_val_3x3 double"
> v.what.rast vector_map rast=raster_map col=rast_val
> r.neighbors raster_map out=raster_map_3x3  # assumes averaging a 3x3
> window
> v.what.rast vector_map rast=raster_map_3x3 col=rast_val_3x3
>  Thanks
> Regards
> helena
> This mail was received via Mail-SeCure System.
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> GIS Consultant, Arava Development Co.http://www.surfaces.co.il
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120329/ac8e2eb0/attachment.html
