[GRASS-user] merge vector layers v.patch
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Mar 30 03:48:54 EDT 2012
On 27/03/12 00:03, Stephen Sefick wrote:
> All:
> I would like to merge seven or so vector objects with similar attribute
> tables. The categories are duplicated and this poses a problem for the
> finished map. It does not show an attribute data. How can I get this to
> work? Any help would be greatly appreciated.
You can run v.category with option=sum and a different value in the
cat= parameter for each of the 7 maps, i.e.
v.category map1 option=sum cat=100
v.category map2 option=sum cat=200
etc
with the value for cat= obviously depending on how many categories you
have in each map.
Once that's done you can patch without fearing duplicate category values.
Maybe v.patch could be enhanced in a way to solve that problem
internally. You can file a wish and see if someone picks it up.
Moritz
