[GRASS-user] Displaying site_name on r.watershed output basins map
Rich Shepard rshepard at appl-ecosys.com
Tue May 1 16:12:13 EDT 2012
On Tue, 1 May 2012, Margherita Di Leo wrote:
> r.to.vect input=basins output=basins feature=area
> Once you have that, you can use v.label to display labels.
   I must be doing something incorrectly. After running r.to.vect I ran
v.label specifying 'value' as the attribute column. No labels display even
after I specify the attribute column, color, and size in the GUI dialog. The
command displayed at the bottom of the GUI dialog box reflects the choices
made above.
   What might inhibit the display of the labels?
Rich
