[GRASS-user] problems with gparser-options in python-script
Johannes Radinger JRadinger at gmx.at
Thu May 3 07:16:25 EDT 2012
I have some questions concerning the behaviour of gparser.
In the attachment you can find a example-python-script.
Somehow the output from gparser for X (see script) is strange: I try
to use it in a if-command but somehow I fail.
The output when X is set to 'A a' should be a "juhuu" but it isn't.
I was looking for the bug in my code but somehow I couldn't find it.
When I  replace the options for X with A,B and C (single Letters), it
seems to work...Is there a problem with spaces in the options of gparser?
I am working on GRASS6.5SVN on Mac OS X 10.6.8.
Can anyone try the script and reproduce the error? Does anyone have ideas where the problem in the script is located?
Thank you for your help.
Best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
Type: text/x-python-script
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120503/4d9648ec/test_script-0001.bin
