[GRASS-user] Euclidean distance (grow.distance) on raster to
certain extent?
Tanya Dyck
tanya.dyck at hotmail.com
Mon May 7 13:05:35 EDT 2012
Thank you Moritz, this worked beautifully!
> Date: Mon, 7 May 2012 18:00:01 +0200
> From: mlennert at club.worldonline.be
> To: lee at isi-solutions.org
> CC: tanya.dyck at hotmail.com; grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Euclidean distance (grow.distance) on raster to certain extent?
> On 07/05/12 16:36, Daniel Lee wrote:
> > Hi Tanya,
> > I would use r.distance rather than r.grow.distance and then reclassify
> > the results to include only areas with <=1108 m distance - that should
> > be a lot easier.
> I don't think r.distance gives what you want, however r.grow.distance
> should be exactly your tool:
> As a starting point you need a raster map with all pixels in the orchard
> non-null and all other pixels null Let's call that raster map
> 'orchard'. Then you can do the following:
> r.grow.distance input=orchard distance=distance_map
> Then, if you only want to see the distance from the orchard to 1108m,
> then you can use r.mapcalc:
> r.mapcalc "final_distance_map=if(distance_map>1108, null(), distance_map)"
> All this keeping in mind that I don't understand what you mean by "I
> recognize this tool does not allow a distance to be included".
> If this means that you also want to measure a distance _within_ the
> orchard, then instead of using a raster map of the orchard, use as input
> to r.grow.distance a raster map with only the center pixel of the
> orchard non-null.
> Moritz
> > 2012/5/7 Tanya Dyck <tanya.dyck at hotmail.com <mailto:tanya.dyck at hotmail.com>>
> > Hello,
> > I am trying to run the grow.distance command to create a raster that
> > displays the euclidean distance from an 'orchard' outward to 1108m.
> > I am not trying to measure the distance between 2 non-null
> > features, but simply wish to have the euclidean distance extend out
> > from the orchard to 1108m. I recognize this tool does not allow a
> > distance to be included so I created a buffer around my orchard
> > (1108m) and intended to run grow.distance on that, however it
> > outputs the distance as if it includes the full raster extent (so I
> > have an output raster of 1108m that is all yellow as opposed to a
> > range of values displaying varying distances) and not limited to my
> > buffer. I want it to assume the buffer extent is the raster extent,
> > so to speak. Is there another way to do this?
> > Any ideas would be much appreciated.
> > Best,
> > Tanya
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120507/e3171c9e/attachment.html
