[GRASS-user] obtain node sequence from v.net.salesman
Gavin Fleming
gavin at afrispatial.co.za
Tue May 8 06:31:20 EDT 2012
this is how I did it:
grass.run_command('g.gisenv', set="DEBUG=2")
p = grass.pipe_command('v.net.salesman', overwrite = True,
_in='network_clean', output='salesman', nlayer=1, ccats=cats)
result = []
for line in p.stdout:
result.append(line)
p.wait()
print result[-2] #this is where the node sequence sits in the debug
output
On 8 May 2012 00:43, Gavin Fleming <gavin at afrispatial.co.za> wrote:
>> The last line of the output should look like this, giving you the
>> category values of the nodes in route order:
>> Nodes' categories (layer 2, 994 nodes):
>> 42,41,164,38,126,15,52,84,16,**55,17,157,60,6,61,8,1,76,72,**46,47,68,24,25,26,28
> How could I parse the 'Nodes categories' array from the debug output (I'm
> stuck with 6.4.1 for now)? More specifically , I need to do it in Python
> with grass.script.
> Gavin
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120508/fe4524da/attachment.html
