[GRASS-user] Calculate stream order from digitized hydrology network
Johannes Radinger jradinger at gmx.at
Mon May 14 09:47:27 EDT 2012
Hi Filipe,
you mean your hydrological network is in vector format?
Maybe you  can try the v.strahler add-on but I don't know
how uptodate this module is:
http://grass.osgeo.org/wiki/GRASS_AddOns#v.strahler
/johannes
Am 14.05.2012 um 13:26 schrieb Filipe Silva Dias:
> Dear all,
> I have a digitized hydrological network and I need to calculate the stream order (Horton, Strahler etc).
> I found r.stream.order but it requires that the hydrological network comes from a DEM, which in my case produced an hydrological network that is considerably different than the digitized one (tried both with r.wateshed, r.terraflow and r.stream.extract).
> Is there a tool capable of doing this? Apparently ArcGIS can do this, but id prefer na open source solution.
> Thanks
> Best regards
> Filipe
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
