[GRASS-user] Identifying Why Vector Map Lables Do Not Display
Rich Shepard
rshepard at appl-ecosys.com
Mon May 28 17:38:24 PDT 2012
On Mon, 28 May 2012, Nick Jachowski wrote:
> I've had this problem before and for me it always seemed to be an issue of
> setting the size of labels correctly, which can be tricky sometimes,
> particularly if your location is latlong (if I remember correctly the size
> is in map units, so in that case you need to compute your desired label
> size as degrees).
> It's been a while since I've had to do this though, so I'm not 100% certain
> of this, but perhaps it will solve your problem.
Nick,
It is a reasonable suggestion, but not the solution here. I raised the
label size from the default 8 pixels to 20 pixels, then 40 pixels, but there
was still no display.
I'm still open to suggestions, recommendations, and solutions.
Thanks,
Rich
Richard B. Shepard, Ph.D. | Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc. | Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
