[GRASS-user] Problems compiling Grass 6.4 and Grass addons under MacOS
David Montoya
jdmonto0 at gmail.com
Tue May 29 20:52:15 PDT 2012
Hi
I installed Grass using the files from kyngchaos and I need to compile some
addons. I tried to install them by two ways, using g.extensions but it
doesn't work, and through modbuild following the instruction but I get the
following error:
My Os is MacOS Lion 10.7
MacBook-Pro-de-Jose:r.stream.extract jdmonto0$ make GRASS_HOME='~/modbuild'
GRASS_APP='/Applications/GRASS-6.4.app'
../../include/Make/Module.make:25: warning: overriding commands for target
`install'
../../include/Make/Rules.make:90: warning: ignoring old commands for target
`install'
gcc -I~/modbuild/dist.i386-apple-darwin11.3.0/include
-I/Applications/GRASS-6.4.app/Contents/MacOS/include -Os -fexceptions
-arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.6.sdk
-I/Library/Frameworks/GDAL.framework/Versions/1.9/Headers
-I/Library/Frameworks/GEOS.framework/Versions/3/unix/include
-DPACKAGE=\""grassmods"\"
-I/Applications/GRASS-6.4.app/Contents/MacOS/include -o
OBJ.i386-apple-darwin11.3.0/close.o -c close.c
In file included from close.c:1:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gis.h:24:19:
error: stdio.h: No such file or directory
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gis.h:651,
from close.c:1:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:42:
error: expected declaration specifiers or ‘...’ before ‘size_t’
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:43:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:44:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:52:
error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
‘G_raster_size’
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:385:
error: expected ‘)’ before ‘*’ token
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:609:
error: expected declaration specifiers or ‘...’ before ‘FILE’
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:610:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:698:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:699:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:749:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:750:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:760:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:762:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:842:
error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:843:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:844:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:845:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:851:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:852:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:854:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:855:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:906:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:929:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:930:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1061:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1088:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1089:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1113:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1114:
error: format string argument not a string type
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1153:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1154:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1248:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1249:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/gisdefs.h:1252:
In file included from close.c:3:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/dbmi.h:153: error:
expected specifier-qualifier-list before ‘FILE’
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/dbmi.h:300,
from close.c:3:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/proto_dbmi.h:231:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/proto_dbmi.h:233:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/proto_dbmi.h:234:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/proto_dbmi.h:332:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_structs.h:16,
from
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/digit.h:3,
from
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/Vect.h:4,
from close.c:4:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/shapefil.h:426:
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/ogr_core.h:33,
from
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/ogr_api.h:42,
from
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_structs.h:22,
from
from
from close.c:4:
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:129:20:
error: stdlib.h: No such file or directory
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:130:18:
error: math.h: No such file or directory
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:132:20:
error: string.h: No such file or directory
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:133:19:
error: ctype.h: No such file or directory
/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/include/limits.h:15,
from
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:134,
from
from
from
from
from
from close.c:4:
/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/include/limits.h:15:25:
error: no include path in which to search for limits.h
from
from
from
from
from close.c:4:
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:137:20:
error: time.h: No such file or directory
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:145:21:
error: errno.h: No such file or directory
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/cpl_port.h:149:22:
error: locale.h: No such file or directory
from
from
from close.c:4:
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/ogr_api.h:105:
/Library/Frameworks/GDAL.framework/Versions/1.9/Headers/ogr_api.h:320:
from
from close.c:4:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_structs.h:67:
error: expected specifier-qualifier-list before ‘FILE’
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_structs.h:415:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/digit.h:4,
from
from close.c:4:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_externs.h:176:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_externs.h:201:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_externs.h:202:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_externs.h:203:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/vect/dig_externs.h:204:
In file included from close.c:4:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/Vect.h:154: error:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/Vect.h:382: error:
/Applications/GRASS-6.4.app/Contents/MacOS/include/grass/Vect.h:420: error:
close.c: In function ‘close_streamvect’:
close.c:39: error: too many arguments to function ‘G__malloc’
close.c:98: error: too many arguments to function ‘G__realloc’
close.c:177: warning: incompatible implicit declaration of built-in
function ‘sprintf’
from close.c:1:
‘G_raster_size’
from close.c:3:
from
from
from close.c:4:
from
from
from
from
from close.c:4:
from
from
from
from
from
from
from close.c:4:
from
from
from
from
from close.c:4:
from
from
from close.c:4:
from
from close.c:4:
from
from close.c:4:
function ‘sprintf’
lipo: can't figure out the architecture type of:
/var/folders/5j/jb8xwzg57kbcpw6sq69_s_gc0000gn/T//cclKMSOW.out
make: *** [OBJ.i386-apple-darwin11.3.0/close.o] Error 1
I tried also to compile Grass by my own, but I get some errors when I run
the command make. The configuration that I use is as follow:
./configure \
--enable-64bit \
--enable-largefile \
--with-freetype \
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
/Library/Frameworks/FreeType.framework/unix/include" \
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
--with-proj \
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-postgres \
--with-postgres-includes="/usr/include/postgresql
/usr/include/postgresql/internal" \
--without-mysql \
--with-odbc \
--with-sqlite \
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include \
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib \
--with-cxx \
--with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
/Library/Frameworks/Tk.framework/Headers
/Library/Frameworks/Tk.framework/PrivateHeaders" \
--with-x \
--without-glw \
--with-opengl=aqua \
--with-python \
--with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.1/bin/wx-config \
--with-ffmpeg \
--with-ffmpeg-includes="/usr/local/include /usr/local/include/libavcodec
/usr/local/include/libavdevice /usr/local/include/libavformat
/usr/local/include/libavutil /usr/local/include/libswscale" \
--with-ffmpeg-libs=/usr/local/lib \
--with-cairo \
--with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo
/Library/Frameworks/cairo.framework/unix/include" \
--with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib \
--with-fftw-includes=/usr/local/include \
--with-fftw-libs=/usr/local/lib \
--with-geos=/Library/Frameworks/GEOS.framework/unix/bin/geos-config \
--with-cairo-ldflags=-lcairo \
--with-blas \
--with-lapack \
--without-readline \
--without-motif \
--without-x11 \
--prefix=/Applications \
--enable-macosx-app
And the result is:
GRASS is now configured for: x86_64-apple-darwin11.4.0
Source directory:
/Users/jdmonto0/Downloads/grass/grass64_release
Build directory:
Installation directory: ${prefix}/GRASS-6.4.app/Contents/MacOS
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: yes
OpenGL platform: Aqua
MacOSX application: yes
MacOSX architectures:
MacOSX SDK:
Tcl/Tk NVIZ: yes
BLAS support: yes
C++ support: yes
Cairo support: yes
DWG support: no
FFMPEG support: yes
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: yes
GLw support: no
LAPACK support: yes
Large File support (LFS): yes
Motif support: no
MySQL support: no
NLS support: no
ODBC support: yes
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: yes
Python support: yes
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: yes
TIFF support: yes
X11 support: no
At this point, everything seems to be ok, but when I run make, I get this
error:
GRASS GIS compilation log
Started compilation: Tue May 29 22:19:23 COT 2012
Errors in:
/Users/jdmonto0/Downloads/grass/grass64_release/lib/iostream
/Users/jdmonto0/Downloads/grass/grass64_release/gui/wxpython
/Users/jdmonto0/Downloads/grass/grass64_release/raster/r.terraflow
/Users/jdmonto0/Downloads/grass/grass64_release/visualization/nviz
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue May 29 22:26:19 COT 2012
make: *** [default] Error 1
I don't know if I'm missing something
Thanks for your help
David Montoya González
Ing. Forestal, Universidad Nacional de Colombia
Laboratorio de Sistemas Complejos, UNAL Medellin
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120529/f591e19a/attachment-0001.html>
