[GRASS-user] installing Grass 7 on ubuntu 11.04
Manish Gautam
manish.gautam29 at gmail.com
Thu Nov 1 05:32:43 PDT 2012
Thanks for your responses.
I followed till this step
http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
(about the ./configure command not working earlier, this time it
worked as I didn't use the ubuntu repository to install rest of the
prerequisites, but downloaded manually and moved to the source code
directory and then configured it accordingly).
In the step of Grass_GIS, ./configure worked (but it says error:
unabale to locate TIFF includes, rest worked).
the step -
compile & install
make -j2 && sudo make install && sudo ldconfig
says "include/Make/Vars.make:1: include/Make/Platform.make: No such
file or directory
make: *** No rule to make target `include/Make/Platform.make'. Stop."
and here I am stuck.
Manish
On 31 October 2012 22:44, Nikos Alexandris <nik at nikosalexandris.net> wrote:
> [forgot to cc to the list]
> Manish Gautam:
> > I am finding it difficult to install Grass 7 on my pc. I use Ubuntu 11.04.
> > I have tried to install it using the instructions given in the link
> > http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu. However, I am able
> > to download and install the dependencies.
> Could you please post the exact command you instructed? And, any positive or
> negative output?
> > Another thing is how the command ./configure is to be used on Ubuntu 11.04.
> > the terminal says the ./configure command not found though the necessary
> > compiler is already been installed on the machine.
> Actually, the "configure" executable file/program is to be ran from within the
> directory in which it is located, i.e. the grass source code root directory.
> From within which directory do you try to execute ./configure? And along with
> which parameters?
> > (Can I download the binary file from here
> > http://grass.fbk.eu/grass70/binary/linux/snapshot/ and install from here ?
> I haven't tried that yet. Maybe someone else can help with this.
> > Though again I am unable to run the installation script given there or
> > extracting the tar file)
> Nikos
