[GRASS-user] Graphical Modeler Output
    Paul Shapley
    p.shapley at gmail.com
    Tue Nov  6 14:20:34 PST 2012
Hi Users,
I'm experimenting with the Graphical Modeler in Grass 6.4.3 but seem to be
having some trouble getting the output to select a monitor and display the
data. Here is the output from a raster to vector conversion.
r.to.vect -s --overwrite
input=grass_15degrees_or_below at PERMANENToutput=grass_15degrees_or_below_modeltest at PERMANENTfeature=area
WARNING: Vector map <grass_15degrees_or_below_modeltest> already exists and
will be overwritten
Extracting areas...
Building topology for vector map <grass_15degrees_or_below_modeltest>...
Registering primitives...
31632 primitives registered
435724 vertices registered
Building areas...
18382 areas built
9878 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 23128
Number of primitives: 31632
Number of points: 0
Number of lines: 0
Number of boundaries: 24422
Number of centroids: 7210
Number of areas: 18382
Number of isles: 9878
Number of areas without centroid: 11172
r.to.vect complete.
(Tue Nov 06 14:01:27 2012) Command finished (16
sec)
2012)
d.monsize setmonitor=x2 setwidth=601
setheight=391
Starting monitor x2 at 601X391 ...
ERROR: no such monitor 'x2'
ERROR: No such monitor as <x2>
Problem selecting x2. Will try once more
Many thanks,
Paul Shapley
Paul J. Shapley
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121106/83a93c03/attachment.html>
