[GRASS-user] r.fuzzy.system output definition
Johannes Radinger
johannesradinger at gmail.com
Wed Nov 7 04:12:20 PST 2012
yes I got r.fuzzy.system working now. The output map in the rule file
must definitely be _OUTPUT_,
nothing else. This is also stated in the text of the article: "A new
GRASS GIS fuzzy inference system
for massive data analysis" in Computers and Geosciences.
But as I followed actually the example of the rule file in the article
(table 3), which is
clearly wrong, I was on the wrong path.
Anyway, everything solved now and it works!
best,
Johannes
>> Hi
>> marker for output definition should be _OUTPUT_ not output. It is explained
>> in description.html more or less in second line. Program treats word output
>> as another input map and cannot find it obviously.
>> If you ask about this snippet it checks if user does not used restricted
>> name _OUTPUT_ as a input map. Probably spurious.
>> cheers
>> J.
> Johannes, can you try? (please also suggest manual page changes if
> needed).
> Markus
