[GRASS-user] Is r.damflood is suitable for grass6.5
SWAPAN GHOSH
swap.ghsh at gmail.com
Thu Nov 8 01:11:22 PST 2012
Dear Roberto,
No I am not working on grass7. I use grass6.5 windows version. So for unix
like flavour we use mingw open source. If possible please give me the
dependent library & header where I can get the used function definition. If
I get then I can try it for old raster library or merge the new library. I
see your code actually some fucnction called here not defined in our
library.
I change some portion like-
/*module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("dambreak"));
G_add_keyword(_("model"));
module->description = _("Estimate the area potentially inundated in case
of dam
break");*/
module->keywords =(_("raster,dambreak,model"));
of dam break");
please see the error for calling-
G_find_raster2
Rast_open_old
Rast_allocate_f_buf
etc.
I am C++ developer if get the new then can redesign the old.
Thanks & Regards,
Swapan
On Thu, Nov 8, 2012 at 2:00 PM, Roberto Marzocchi <
roberto.marzocchi at gmail.com> wrote:
> Dear Swapan,
> I think that the actually code of r.damflood don't work with grass 6.5
> (I'm sure about grass6) because we used the new raster libraries of grass7.
> We start the development in Grass 6.4.0 after we encountered a few
> libraries problem starting from Grass 6.4.1 so we carry on the development
> in grass7.
> Moreover I never compile a C command in Mingw (I use normally linux),
> hence I am not sure to understand what you ask me.
> Have you tried to compile the command in Grass 7?
> Best regards,
> Roberto
> 2012/11/8 SWAPAN GHOSH <swap.ghsh at gmail.com>
>> Dear Roberto,
>> I am trying to compile source code in Mingw environment for r.damflood.
>> But I have a problem that some libary is missing in my environment. Can you
>> please send me the .exe file by remaning as r.damflood.txt. Is it run
>> succesfully in Grass6.5.
>> Thanks & Regards,
>> Swapan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121108/3169dedb/attachment.html>
