[GRASS-user] log(0)-error in r.mapcalculator
Patrick S.
patrick_GIS at gmx.ch
Fri Nov 9 00:27:19 PST 2012
Thank you so much, Markus!
That was the missing hint and it works now!
However, I just went through the documentation, which says: "/F/ means
that the functions always results in a floating point value" and
Function "log" has "F".
This is somehow misleading and rather should be an "*". Can I correct
that somewhere without access-rights (to contribute) or would I rather
report this?
Patrick
that On 11/08/2012 07:34 PM, Markus Metz wrote:
> On Thu, Nov 8, 2012 at 10:50 AM, Patrick S. <patrick_GIS at gmx.ch> wrote:
>> Dear List,
>> I keep getting a log(0) error in r.mapcalculator, even if I enlarge the
>> data. This seems to be a bug as I controlled the same data with R and get
>> (non-infinity) values. Does r.mapcalculator eventually truncate the results
>> of formulas to some integer values?
>> logit-expression: log(((A/100)/(1-(A/100)))
> In r.mapcalc, the numbers are treated as integers. Try instead log(((A
> / 100.0) / (1.0 - (A / 100.0)))
> Changing e.g. 1 to 1.0 forces r.mapcalc to do floating point calculations.
> HTH,
> Markus M
>> To avoid error of log(0) I enlarged the data by 0.00001, 1 and 5 but keep
>> getting the error.
>> I run it out of R with:
>> param<-list(amap="r_slope_perc", formula="log(((A+0.00001)/100)/(1-(A/100)))
>> ", outfile="r_slope_perc_logit")
>> execGRASS("r.mapcalculator", parameters=param, flags=c("overwrite"))
>> (r.mapcalculator amap="r_slope_perc",
>> formula="log(((A+0.00001)/100)/(1-(A/100)))" outfile="r_slope_perc_logit"
>> --overwrite)
>> Any ideas why this happens?
>> Patrick
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121109/1b32cace/attachment.html>
