[GRASS-user] Easy way to patch vector files
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Fri Nov  9 17:01:22 PST 2012
Stephen -
Adding an attribute table to the input map is probably the best thing to do!
You can create the patched vector with no attribute table, and add it
later - but you'll then have to go back and use other tools to create a
table and fetch attributes from the original.
cheers,
Richard Chirgwin
On 10/11/12 7:00 AM, grass-user-request at lists.osgeo.org wrote:
> I have two different vectors that I would like to patch together.  one
> doesn't have an attribute table associated with it.  The other does.  I
> am having a problem figuring out how to get them to play nicely.  At
> this point It would be easier to just create an attribute table...  All
> help is greatly appreciated.  I will provide any information that you
> all need to help.  Many thanks in advance.
