[GRASS-user] Two warnings on grass642 and compiled grass643/65/70svn
王德辉
dehuiw at gig.ac.cn
Thu Nov 15 04:36:48 PST 2012
Hi all,
There are tow warnings puzzled me. (1) when running "g.gui wxpython" in grass643svn/grass65svn/grass70svn on ubuntu, will appear a warning "
(.:3615): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent."
(2) when running the default grassgis6.4.2 in ubuntu software center,
GRASS 6.4.2 (nc_spm_08):~ > g.region -p
g.region: /usr/local/lib/libgdal.so.1: no version information available (required by /usr/lib/grass64/lib/libgrass_vect.6.4.2.so)
g.region: /usr/local/lib/libgdal.so.1: no version information available (required by /usr/lib/grass64/lib/libgrass_gproj.6.4.2.so)
this does not appear in grass6.4.3svn grass6.5.0svn grass70svn, and aslo not appear when install the grass642 first (in my case I install grass642 from the ubuntu software center after compiling and installing the grass6.4.3svn grass6.5.0svn grass70svn).
GRASS 6.4.2 (nc_spm_08):~ > g.version -b
GRASS 6.4.2 (2012)
./configure --host=x86_64-linux-gnu --build=x86_64-linux-gnu --prefix=/usr/lib --sysconfdir=/etc --sharedstatedir=/var --enable-socket --enable-shared --with-postgres --with-mysql --with-cxx --with-x --with-gdal --with-freetype --with-motif --with-readline --with-nls --with-odbc --with-sqlite --enable-largefile --with-freetype-includes=/usr/include/freetype2 --with-tcltk-includes=/usr/include/tcl --with-postgres-includes=/usr/include/postgresql --with-mysql-includes=/usr/include/mysql --with-proj-share=/usr/share/proj --with-wxwidgets=/usr/bin/wx-config --with-python=/usr/bin/python-config --with-cairo
GRASS 6.4.3svn (nc_spm_08):~ > g.version -b
GRASS 6.4.3svn (2012)
./configure --enable-debug --enable-64bit --with-readline --with-cxx --with-python=yes --with-proj-share=/usr/local/share/proj/ --with-geos=/usr/local/bin/geos-config --with-cairo --with-tcltk-includes=/usr/include/tcl8.5/ --with-opengl-libs=/usr/include/GL --with-motif --with-ffmpeg=yes '--with-ffmpeg-includes=/usr/include/libavcodec /usr/include/libavformat /usr/include/libswscale' --with-blas --with-lapack --with-nls --with-freetype=yes --with-freetype-includes=/usr/include/freetype2/ --enable-largefile=yes --with-wxwidgets --with-postgres=yes --with-postgresql=yes --with-postgres-includes=/usr/include/postgresql --with-sqlite=yes --with-mysql=yes --with-mysql-includes=/usr/include/mysql --with-odbc=yes
GRASS 6.4.3svn (nc_spm_08):~ > ls /usr/lib/libgdal.so.*
/usr/lib/libgdal.so.1 /usr/lib/libgdal.so.1.16.2
GRASS 6.4.3svn (nc_spm_08):~ > ls /usr/local/lib/libgdal.so.*
/usr/local/lib/libgdal.so.1 /usr/local/lib/libgdal.so.1.16.2
Best wishes,
dehui
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121115/809786f0/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121115/809786f0/attachment.txt>
