[GRASS-user] Problems in adding tables to a map
Aldo Clerici
aldo.clerici at unipr.it
Sat Nov 17 02:42:25 PST 2012
GRASS user,
I'm having some problem in connecting tables to a map.
This is the procedure (in order to simplify I used the same table but with
different names) :
g.copy vect=roads,roads1
g.copy vect=roads,roads2
The two tables are in the table list.
db.tables -p
v.db.connect map=roads1 table=roads2 layer=2
The connections seem ok:
v.db.connect -p map=roads1
Vector map <roads1 at esercizi> is connected by:
layer <1> table <roads1> in database
</home/clerici/GRASSdata/spearfish60/esercizi/dbf/> through driver <dbf>
with key <cat>
layer <2> table <roads2> in database
with key <cat>
But:
d.mon x0
This displays the map with lines and labels
d.vect map=roads1 disp=shape,attr attrcol=label layer=1
This doesn't produce any output
d.erase
d.vect map=roads1 disp=shape,attr attrcol=label layer=2
I tried a check by producing the ASCII file with:
v.out.ascii in=roads1 form=standard
but after each sequence of coordinates only layer 1 is reported
L 6 1
590744.10526028 4926835.64296535
590742.5374415 4926835.30309294
590624.60065406 4926810.04019906
590503.0158192 4926784.15943798
590383.85077876 4926762.55284068
590253.15645239 4926731.77335036
1 4
L 2 1
591497.07137115 4926772.322352
591667.99469283 4926778.18725746
1 4
Another check with:
v.extract in=roads1 out=roads_extr layer=2 list=1-3
produces an empty map.
Did I miss something in the connection command?
Thanks
Aldo Clerici
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121117/60074e07/attachment-0001.html>
