[GRASS-user] Finally got working GDAL stable v 1.9.2 GRASS v7.0 and their Plugin!
Pankaj Kr Sharma
pkscwc at gmail.com
Thu Nov 22 01:26:53 PST 2012
Installing GDAL and GRASS was the easier part.
Just followed all the instructions posted on the wiki.
Building the plugin required some effort.
I resolved the errors cropping up during installation through crude methods.
The plugin worked finally and got it tested also.
The Long messages received during installation and the plugin files are
also attached.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121122/962ed30a/attachment-0001.html>
---------------gdal-grass plugin begins ---------------------
./configure \
--prefix=/usr/local \
--with-gdal=/usr/local/bin/gdal-config \
--with-grass=/usr/local/grass-7.0.svn/ \
--with-autoload="/usr/local/lib/gdalplugins/" \
--with-ld-shared="g++ -shared"
Here, I have used installation folder path instead of source path for GRASS.
rdcgis2 at rdcgis2-nswdc:/usr/gis/gdal-grass-plugin$ make
g++ -Wall -fPIC -DUSE_CPL -DGRASS_GISBASE=\"/usr/local/grass-7.0.svn/\" -I/usr/local/include -I/usr/local/grass-7.0.svn//include -c -o grass57dataset.o grass57dataset.cpp
grass57dataset.cpp:50:38: error: declaration of C function ?char* GPJ_grass_to_wkt(Key_Value*, Key_Value*, int, int)? conflicts with
In file included from /usr/local/grass-7.0.svn//include/grass/gprojects.h:91:0,
from grass57dataset.cpp:45:
/usr/local/grass-7.0.svn//include/grass/defs/gprojects.h:17:7: error: previous declaration ?char* GPJ_grass_to_wkt(const Key_Value*, const Key_Value*, int, int)? here
make: *** [grass57dataset.o] Error 1
Done the correction
char *GPJ_grass_to_wkt(const struct Key_Value *proj_info,
const struct Key_Value *proj_units,
int esri_style, int prettify);
Again , error
g++ -shared grass57dataset.o -L/usr/local/grass-7.0.svn//lib -lgrass_raster.7.0.svn -lgrass_gmath.7.0.svn -lgrass_gis.7.0.svn -lgrass_datetime.7.0.svn -lgrass_gproj.7.0.svn -lgrass_vector.7.0.svn -lgrass_dbmibase.7.0.svn -lgrass_dbmiclient.7.0.svn -lgrass_dgl.7.0.svn -lgrass_dig2.7.0.svn -lgrass_rtree.7.0.svn -lgrass_linkm.7.0.svn -lgrass_btree2.7.0.svn -lgrass_ccmath.7.0.svn -L/usr/local/lib -lgdal -o gdal_GRASS.so
g++ -Wall -fPIC -DUSE_CPL -DGRASS_GISBASE=\"/usr/local/grass-7.0.svn/\" -I/usr/local/include -I/usr/local/grass-7.0.svn//include -c -o ogrgrassdriver.o ogrgrassdriver.cpp
In file included from /usr/local/grass-7.0.svn//include/grass/vect/digit.h:3:0,
from /usr/local/grass-7.0.svn//include/grass/vector.h:4,
from ogrgrass.h:41,
from ogrgrassdriver.cpp:30:
/usr/local/grass-7.0.svn//include/grass/vect/dig_structs.h:34:22: fatal error: libpq-fe.h: No such file or directory
compilation terminated.
make: *** [ogrgrassdriver.o] Error 1
corrected it with
#ifdef HAVE_POSTGRES
#include </usr/include/postgresql/libpq-fe.h>
#endif
Again , error
g++ -Wall -fPIC -DUSE_CPL -DGRASS_GISBASE=\"/usr/local/grass-7.0.svn/\" -I/usr/local/include -I/usr/local/grass-7.0.svn//include -c -o ogrgrassdatasource.o ogrgrassdatasource.cpp
ogrgrassdatasource.cpp: In member function ?int OGRGRASSDataSource::Open(const char*, int, int, int)?:
ogrgrassdatasource.cpp:191:28: error: ?GV_FATAL_PRINT? was not declared in this scope
ogrgrassdatasource.cpp:191:43: error: ?Vect_set_fatal_error? was not declared in this scope
make: *** [ogrgrassdatasource.o] Error 1
corrected it with
/* Vect_set_fatal_error ( GV_FATAL_PRINT ); // Print error and continue */
And, my plugin completed the make stage successfully.
Now, the sudo checkinstall time:
Again , error
========================= Installation results ===========================
install -d /usr/local/lib/gdalplugins/
cp gdal_GRASS.so /usr/local/lib/gdalplugins/
cp ogr_GRASS.so /usr/local/lib/gdalplugins/
test -d /usr/local/share/gdal/grass || mkdir /usr/local/share/gdal/grass
test -d /usr/local/share/gdal/grass/etc || mkdir /usr/local/share/gdal/grass/etc
cp /usr/local/grass-7.0.svn//etc/ellipse.table /usr/local/share/gdal/grass/etc
cp: cannot stat `/usr/local/grass-7.0.svn//etc/ellipse.table': No such file or directory
make: *** [install] Error 1
**** Installation failed. Aborting package creation.
Cleaning up...OK
Bye.
corrected it with
sudo cp /usr/gis/grass_trunk/lib/gis/ellipse.table /usr/local/grass-7.0.svn/etc/ellipse.table
Sudo Checkinstall again
cp /usr/local/grass-7.0.svn//etc/datum.table /usr/local/grass-7.0.svn//etc/datumtransform.table /usr/local/share/gdal/grass/etc
cp: cannot stat `/usr/local/grass-7.0.svn//etc/datum.table': No such file or directory
cp: cannot stat `/usr/local/grass-7.0.svn//etc/datumtransform.table': No such file or directory
Restoring overwritten files from backup...OK
Cleaning up...OK
Bye.
corrected it with
sudo cp /usr/gis/grass_trunk/lib/gis/datumtransform.table /usr/local/grass-7.0.svn/etc/datumtransform.table
sudo cp /usr/gis/grass_trunk/lib/gis/datum.table /usr/local/grass-7.0.svn/etc/datum.table
And it worked.
Done. The new package has been installed and saved to
/usr/gis/gdal-grass-plugin/gdal-grass_5-1_amd64.deb
You can remove it from your system anytime using:
dpkg -r gdal-grass
Now , it is time to test:
test 1
rdcgis2 at rdcgis2-nswdc:~$ gdal_translate --formats | grep -i grass
GRASS (ro): GRASS Database Rasters (5.7+)
GRASSASCIIGrid (rov): GRASS ASCII Grid
test 2
ldd /usr/local/lib/gdalplugins/gdal_GRASS.so
linux-vdso.so.1 => (0x00007fff30fee000)
libgrass_raster.7.0.svn.so => /usr/local/grass-7.0.svn/lib/libgrass_raster.7.0.svn.so (0x00007f3443314000)
libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f3438371000)
test 3
rdcgis2 at rdcgis2-nswdc:~$ ldd /usr/local/lib/gdalplugins/ogr_GRASS.so
linux-vdso.so.1 => (0x00007fffb2fbb000)
libgrass_gis.7.0.svn.so => /usr/local/grass-7.0.svn/lib/libgrass_gis.7.0.svn.so (0x00007f858d980000)
libssl.so.1.0.0 => /lib/x86_64-linux-gnu/libssl.so.1.0.0 (0x00007f858784a000)
libcrypto.so.1.0.0 => /lib/x86_6
test 4
rdcgis2 at rdcgis2-nswdc:~$ gdalinfo /media/rdcgis2/disk2part3/rdcgis2/gisdata90m/no_nulls/cellhd/i90
Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
Driver: GRASS/GRASS Database Rasters (5.7+)
Files: /media/rdcgis2/disk2part3/rdcgis2/gisdata90m/no_nulls/cellhd/i90
Size is 42001, 42001
Coordinate System is:
GEOGCS["everest",
DATUM["unknown",
SPHEROID["Everest_1830_India",6377276.345,300.8017]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Origin = (64.999583454444448,40.000416763611113)
Pixel Size = (0.000833333333333,-0.000833333333333)
Corner Coordinates:
Upper Left ( 64.9995835, 40.0004168) ( 64d59'58.50"E, 40d 0' 1.50"N)
Lower Left ( 64.9995835, 4.9995834) ( 64d59'58.50"E, 4d59'58.50"N)
Upper Right ( 100.0004168, 40.0004168) (100d 0' 1.50"E, 40d 0' 1.50"N)
Lower Right ( 100.0004168, 4.9995834) (100d 0' 1.50"E, 4d59'58.50"N)
Center ( 82.5000001, 22.5000001) ( 82d30' 0.00"E, 22d30' 0.00"N)
Band 1 Block=42001x1 Type=Int32, ColorInterp=Gray
Min=-160.000 Max=8806.000
NoData Value=-2147483648
Metadata:
COLOR_TABLE_RULES_COUNT=0
test 5
rdcgis2 at rdcgis2-nswdc:~$ ogrinfo -summary /media/rdcgis2/disk2part3/rdcgis2/find_sites/find_sites_vector/PERMANENT/vector/new1917_online/head
DBMI-PostgreSQL driver error:
Connection failed.
fe_sendauth: no password supplied
Warning 1: GRASS warning: Unable to open database <host=localhost,dbname=nswdc_gis> by driver <pg>
ERROR 1: Cannot open database pg by driver host=localhost,dbname=nswdc_gis, check if GISBASE enviroment variable is set, the driver is available and the database is accessible.
INFO: Open of `/media/rdcgis2/disk2part3/rdcgis2/find_sites/find_sites_vector/PERMANENT/vector/new1917_online/head'
using driver `GRASS' successful.
1: new1917_online (Point)
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121122/962ed30a/attachment-0001.bin>
