[GRASS-user] Does v.kernel have to take 16+ hours?
Aren Cambre
aren at arencambre.com
Fri Nov 23 05:07:28 PST 2012
Isn't taking about 10,000% too much time considered a bug? :-)
On Nov 23, 2012 5:11 AM, "Markus Metz" <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Nov 23, 2012 at 4:14 AM, Aren Cambre <aren at arencambre.com> wrote:
> > I'm able to reproduce reliably here. I'll email you details privately.
> Thanks. I can confirm that v.kernel takes a long time in GRASS 6 with
> the settings provided by you. It does not crash, however.
> I can speed up v.kernel in GRASS 6 to complete in 10 minutes instead
> of 16+ hours, but I am not sure if this fix can/will go into GRASS 6.4
> because by now only bugs should be fixed.
> Markus M
> > Aren
> > On Thu, Nov 22, 2012 at 9:02 AM, Markus Metz <
> > wrote:
> >> On Sat, Nov 17, 2012 at 4:06 PM, Aren Cambre <aren at arencambre.com>
> wrote:
> >> > I have a dataset of just over 700,000 incidents that happened in
> >> > square-ish
> >> > Texas county that's about 30 miles on each side.
> >> > Here's the parameters reported by v.kernel as it's executing:
> >> > STDDEV: 1000.000000
> >> > RES: 111.419043 ROWS: 458 COLS: 447
> >> > Writing output raster map using smooth parameter=1000.000000.
> >> > Normalising factor=6482635.018778.
> >> > I am running this on a Windows 7 x64 machine with 8 GB RAM and an
> Intel
> >> > Core
> >> > i7 Q720 1.6 GHz with 4 physical cores. I notice that it's not
> >> > multithreaded,
> >> > only using 1 core.
> >> > It takes about 16 hours to complete. Is this correct? I'd like to use
> >> > this
> >> > on a dataset with closer to 5 million records, and I'm really
> concerned
> >> > how
> >> > long it may take.
> >> The time required by v.kernel is a function of the number of cells and
> >> the input parameter stddeviation. The larger any of these values is,
> >> the more time v.kernel will need. Nevertheless, I think that the 16+
> >> hours are not correct. I tested with a vector with 3 million points
> >> for a grid with 2700 rows and 1087 columns, magnitudes larger than the
> >> grid used by you. v.kernel completes in just over one minute.
> >> > I posted my question about the 16+ hours at
> http://gis.stackexchange.com/questions/41058/how-do-i-compute-v-kernel-maps-in-less-than-16-hours/
> >> > Bill Huber, who si apparently knowledgeable about kernel density
> >> > calculations in general, posted a response, and he felt like a kernel
> >> > density map shouldn't take much time at all. But digging more deeply,
> >> > turns
> >> > out he had come up with a kernel density calculation method over a
> >> > decade
> >> > ago using Fourier transforms. See
> >> > http://www.directionsmag.com/features/convolution/129753 and the next
> >> > two
> >> > articles linked to it (they are short articles). Apparently this
> >> > transforms
> >> > it from an O(n^2) problem to an O(n ln n) complexity problem.
> >> The approach of Bill Huber is raster-based, not vector based, making
> >> some things easier, at the cost of precision. The coordinate
> >> precision, however, is only needed for kernel functions other than
> >> uniform. In GRASS, you could get something like a raster-based density
> >> map by
> >> - exporting the points with v.out.ascii
> >> - re-importing the points with r.in.xyz method=n to get the number of
> >> points per cell
> >> - running a neighborhood analysis using a circular window with
> >> r.neighbors method=sum -c
> >> Optionally you could use the gauss option of r.neighbors to get an
> >> equivalent to v.kernel kernel=gaussian
> >> HTH,
> >> Markus M
> >> > I inspected v.kernel's main.c
> http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.kernel/main.c),
> >> > and looks like v.kernel uses an output-centric method (using Bill's
> >> > wording)
> >> > of calculating the output, which seems like O(n^2) complexity.
> >> > So I guess what I'm getting at is it appears to me that the algorithm
> >> > behind
> >> > GRASS GIS's v.kernel is straightforward but is a greedy algorithm
> >> > (http://en.wikipedia.org/wiki/Greedy_algorithm), which is fine, but
> it
> >> > make
> >> > take a while to execute. Is this true?
> >> > Is there not spatial indexing I could add to the dataset? I've done
> >> > various
> >> > Google searches on that and can't come up with anything clear.
> >> > Aren
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121123/c944003a/attachment-0001.html>
