[GRASS-user] Error in windows version of i.spectral
    SWAPAN GHOSH
    swap.ghsh at gmail.com
    Wed Nov 28 02:26:42 PST 2012
Do you have complete solution for i.spectral in windows. Before, you
telling I am trying, installing gnuplot and set the path variable. But
still there prob with d.mon.
I need this command very much. If you have any alternative solution then
suggest me. As I need spectral responses in user specified region.
Thanks & Regards,
Swapan
Date: Mon, 26 Nov 2012 03:55:11 -0800 (PST)
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Error in windows version of i.spectral
Message-ID: <1353930911864-5018732.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
>i.spectral is not running under windows version grass. I use here Grass 6.4
for windows.
>How I can fix the problem. If there is any other alternative for windows
then suggest me
>or fix the error for i.spectral.
>i.spectral works fine for linux but I need it for windows.
gnuplot [1] is needed for i.spectral, but gnuplot isn't part of
osgeo4w-wingrass/wingrass-standalone
try
- install gnuplot from [1]
- put path/to/gnuplot in %PATH%
[1] http://www.gnuplot.info/
best regards
Helmut
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Error-in-windows-version-of-i-spectral-tp5018720p5018732.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121128/40c6ebe9/attachment.html>
