[GRASS-user] Error in windows version of i.spectral
SWAPAN GHOSH swap.ghsh at gmail.com
Thu Nov 29 01:00:47 PST 2012
can you please attached me the screen shot for i.spectral specifically
command window.
Regards,
Swapan
On Thu, Nov 29, 2012 at 2:21 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> d.mon x0 isn't available in windows. a d.mon x0-alternative in
> wingrass-i.spectral would be needed.
> but
> tested here with osgeo4w-wingrass7 [1] and the following manual example
> [2] works for me:
> g.region rast=lsat7_2002_10 -p
> i.spectral -g
> raster=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
>            coordinates=636069,215440,637958,223393,633277,223605
> path/to/gnuplot must be in %PATH%.
> best regards
> Helmut
> [1]http://trac.osgeo.org/osgeo4w/
> [2]http://grass.osgeo.org/grass70/manuals/i.spectral.html
> Gesendet: Mittwoch, 28. November 2012 um 11:26 Uhr
> Von: "SWAPAN GHOSH" <swap.ghsh at gmail.com>
> An: hellik at web.de
> Cc: grass-user <grass-user at lists.osgeo.org>
> Betreff: Re: Error in windows version of i.spectral
> Hi,
> Do you have complete solution for i.spectral in windows. Before, you
> telling I am trying, installing gnuplot and set the path variable. But
> still there prob with d.mon.
> I need this command very much. If you have any alternative solution then
> suggest me. As I need spectral responses in user specified region.
> Thanks & Regards,
> Swapan
> Date: Mon, 26 Nov 2012 03:55:11 -0800 (PST)
> From: Helmut Kudrnovsky <hellik at web.de>
> To: grass-user at lists.osgeo.org[grass-user at lists.osgeo.org]
> Subject: Re: [GRASS-user] Error in windows version of i.spectral
> Message-ID: <1353930911864-5018732.post at n6.nabble.com[
> 1353930911864-5018732.post at n6.nabble.com]>
> Content-Type: text/plain; charset=us-ascii
> >i.spectral is not running under windows version grass. I use here Grass
> 6.4
> for windows.
> >How I can fix the problem. If there is any other alternative for windows
> then suggest me
> >or fix the error for i.spectral.
> >i.spectral works fine for linux but I need it for windows.
> gnuplot [1] is needed for i.spectral, but gnuplot isn't part of
> osgeo4w-wingrass/wingrass-standalone
> try
> - install gnuplot from [1]
> - put path/to/gnuplot in %PATH%
> [1] http://www.gnuplot.info/[http://www.gnuplot.info/]
> best regards
> Helmut
> http://osgeo-org.1560.n6.nabble.com/Error-in-windows-version-of-i-spectral-tp5018720p5018732.html[http://osgeo-org.1560.n6.nabble.com/Error-in-windows-version-of-i-spectral-tp5018720p5018732.html]
> Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121129/9777a095/attachment.html>
