[GRASS-user] Error in windows version of i.spectral
    SWAPAN GHOSH
    swap.ghsh at gmail.com
    Thu Nov 29 01:43:44 PST 2012
I am telling command windows that is command output for i.spectral.
like-
[image: Inline image 1]
It seem to be error is fixed for grass7.
Thanks & Regards,
Swapan
On Thu, Nov 29, 2012 at 2:30 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> can you please attached me the screen shot for i.spectral specifically
> command window.
> Regards,
> Swapan
> On Thu, Nov 29, 2012 at 2:21 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> hi,
>> d.mon x0 isn't available in windows. a d.mon x0-alternative in
>> wingrass-i.spectral would be needed.
>> but
>> tested here with osgeo4w-wingrass7 [1] and the following manual example
>> [2] works for me:
>> g.region rast=lsat7_2002_10 -p
>> i.spectral -g
>> raster=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
>>            coordinates=636069,215440,637958,223393,633277,223605
>> path/to/gnuplot must be in %PATH%.
>> best regards
>> Helmut
>> [1]http://trac.osgeo.org/osgeo4w/
>> [2]http://grass.osgeo.org/grass70/manuals/i.spectral.html
>> Gesendet: Mittwoch, 28. November 2012 um 11:26 Uhr
>> Von: "SWAPAN GHOSH" <swap.ghsh at gmail.com>
>> An: hellik at web.de
>> Cc: grass-user <grass-user at lists.osgeo.org>
>> Betreff: Re: Error in windows version of i.spectral
>> Hi,
>> Do you have complete solution for i.spectral in windows. Before, you
>> telling I am trying, installing gnuplot and set the path variable. But
>> still there prob with d.mon.
>> I need this command very much. If you have any alternative solution then
>> suggest me. As I need spectral responses in user specified region.
>> Thanks & Regards,
>> Swapan
>> Date: Mon, 26 Nov 2012 03:55:11 -0800 (PST)
>> From: Helmut Kudrnovsky <hellik at web.de>
>> To: grass-user at lists.osgeo.org[grass-user at lists.osgeo.org]
>> Subject: Re: [GRASS-user] Error in windows version of i.spectral
>> Message-ID: <1353930911864-5018732.post at n6.nabble.com[
>> 1353930911864-5018732.post at n6.nabble.com]>
>> Content-Type: text/plain; charset=us-ascii
>> >i.spectral is not running under windows version grass. I use here Grass
>> 6.4
>> for windows.
>> >How I can fix the problem. If there is any other alternative for windows
>> then suggest me
>> >or fix the error for i.spectral.
>> >i.spectral works fine for linux but I need it for windows.
>> gnuplot [1] is needed for i.spectral, but gnuplot isn't part of
>> osgeo4w-wingrass/wingrass-standalone
>> try
>> - install gnuplot from [1]
>> - put path/to/gnuplot in %PATH%
>> [1] http://www.gnuplot.info/[http://www.gnuplot.info/]
>> best regards
>> Helmut
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Error-in-windows-version-of-i-spectral-tp5018720p5018732.html[http://osgeo-org.1560.n6.nabble.com/Error-in-windows-version-of-i-spectral-tp5018720p5018732.html]
>> Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121129/9f3c267a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121129/9f3c267a/attachment-0001.png>
