[GRASS-user] SUSE 12.2 rpm
    Angelos Tzotsos
    gcpp.kalxas at gmail.com
    Thu Nov 29 08:18:44 PST 2012
Hi Bob,
The repository you install from is a mirror of download.opensuse.org. It
should be working ok.
When I trigger a chroot build using grass in 32bit environment I do not
get the same error.
I will test on a new SUSE Studio VM.
Angelos
On 11/29/2012 05:10 PM, Bob Siegfried wrote:
> Angelos,
> The repository from which I downloaded the both rpms was
> anorien.csc.warwick.ac.uk.
> Thanks,
> Bob
> On 11/28/2012 1:37 AM, Angelos Tzotsos wrote:
>> Hi Bob, Daniel.
>> I am in the process of updating to 6.4.3 but I am waiting for the
>> final version to push to Application:Geo.
>> https://build.opensuse.org/project/monitor?project=home%3Atzotsos%3AApplication%3AGeo
>> Bob, can you please provide a list of the repositories you have on
>> your system?
>> Also, what openSUSE version do you have installed?
>> Best,
>> Angelos
>> On 11/28/2012 10:25 AM, Daniel Lee wrote:
>>> Hi Bob,
>>> Is your machine running 32 bit? I'm running OpenSUSE 12.2 64-bit and
>>> haven't had any problems installing 6.4 from the Geo repository. I
>>> can't
>>> test the 32-bit version though. Or can you ignore the dependency?
>>> Best,
>>> Daniel
>>> 2012/11/28 Bob Siegfried<robtsiegfried at gmail.com>
>>>> Hello,
>>>> I get a Catch 22 when downloading the GRASS 6.4.2.1-2.23.i586.rpm.
>>>> Installation fails because there is a grass-docs dependency.
>>>> Similarly, grass-docs- 6.4.2.1-2.23.i586.rpm installation fails
>>>> because of
>>>> a GRASS 6.4.2.1-2.23.i586 dependency. Would appreciate
>>>> any suggestions.
>>>> Thanks,
>>>> Bob
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121129/b1ec0c9d/attachment.html>
