[GRASS-user] urgently:(((please
Sören Gebbert
soerengebbert at googlemail.com
Mon Oct 1 07:18:45 PDT 2012
Simply specify the location and mapset with absolute path at the
command line in "text" mode:
grass70 -text /home/soeren/grassdata/LL/PERMANENT
grass70 --help
Usage:
grass70 [-h | -help | --help] [-v | --version] [-c | -c geofile | -c
EPSG:code]
[-text | -gui] [--config param]
[[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]
Flags:
-h or -help or --help print this help message
-v or --version show version information and exit
-c create given database, location or
mapset if it doesn't exist
-text use text based interface
and set as default
-gui use wxpython graphical user interface
and set as default
--config print GRASS configuration parameters
options: arch,build,compiler,path,revision
Parameters:
GISDBASE initial database (path to GIS data)
LOCATION_NAME initial location
MAPSET initial mapset
GISDBASE/LOCATION_NAME/MAPSET fully qualified initial mapset directory
Environment variables relevant for startup:
GRASS_GUI select GUI (text, gui)
GRASS_WISH set wish shell name to override 'wish'
GRASS_HTML_BROWSER set html web browser for help pages
GRASS_ADDON_PATH set additional path(s) to local GRASS
modules or user scripts
GRASS_ADDON_BASE set additional GISBASE for locally
installed GRASS Addons
GRASS_BATCH_JOB shell script to be processed as batch job
GRASS_PYTHON set python shell name to override 'python'
2012/10/1 Albert Saribekyan <albertsaribekyan at rambler.ru>:
> Albert Saribekyan.
> Sorry I forgot to mention I must do it in GRASS7.0, in 6.* i did it!!
> so help me..
> my GRASS starts following:
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS 7.0.svn
> GRASS homepage: http://grass.osgeo.org
> This version running through: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> Start the GUI with: g.gui wxpython
> When ready to quit enter: exit
> GRASS 7.0.svn (orinak):~ >
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
