[GRASS-user] urgently:(((please
Daniel Lee lee at isi-solutions.org
Mon Oct 1 07:40:30 PDT 2012
Cluster, cool ;)
Okay, the first step is to identify what you want to do and then fins the
command that let's you do it. My suggestion would be to install grass on a
normal work station and then try working with it with the GUI. Each command
that you perform with the mouse is also a protocoled text command, which
you can see and use to plan your own text commands.
Of course it is possible to change locations without a GUI. When you start
GRASS, it asks you what location you want to be in. Just enter the location
and mapset that you want to use and you'll be using it. Just exit out of
GRASS with Ctrl+D and start GRASS again.
Am 01.10.2012 16:04 schrieb "Albert Saribekyan" <albertsaribekyan at rambler.ru
> Dear daniel Im working in claster(server) and there aren't GUI!!!:(((((((((
> Albert Saribekyan.
>  1 Октябрь 2012 г. 17:57:54 пользователь Daniel Lee (lee at isi-solutions.org)
>> написал:
>> Hi Albert,
>> It's very hard to help you with such a general question. If you are
>> trying to start the GUI, why don't you try entering g.gui wxpython? Then
>> you can manage what you're trying to do with graphical menus.
>> What you're seeing is the normal GRASS GIS start menu, it's where you
>> start everything from, so in principle you've started the program. You just
>> need to do whatever your plan is. Sorry to give you a negative answer, but
>> without specifics there's no way to help.
>> Best,
>> Daniel
>> On Monday, October 01, 2012 17:55:50 Albert Saribekyan wrote:
>> > > Albert Saribekyan.
>> > > > Sorry I forgot to mention I must do it in GRASS7.0,      in 6.* i
>> did it!!
>> > so help me..
>> > my GRASS starts following:
>> > >                       __________    ___      __________
>>      _______________
>> >                     / ____/ __ \/      | / ___/ ___/      / ____/    _/
>> ___/
>> >                  / / __/ /_/ / /| | \__ \\_    \      / / __ / / \__ \
>> >                / /_/ / _, _/ ___ |___/ /__/ /    / /_/ // / ___/ /
>> >                \____/_/ |_/_/    |_/____/____/      \____/___//____/
>> > > Welcome to GRASS 7.0.svn
>> > GRASS homepage:
>>          http://grass.osgeo.org
>> > This version running through:                               Bash Shell
>> (/bin/bash)
>> > Help is available with the command:          g.manual -i
>> > See the licence terms with:                                   g.version
>> -c
>> > Start the GUI with:
>>          g.gui wxpython
>> > When ready to quit enter:                                       exit
>> > > GRASS 7.0.svn (orinak):~ >
>> > > > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
2012/10/1 Albert Saribekyan <albertsaribekyan at rambler.ru>
> Albert Saribekyan.
>> написал:
>> Hi Albert,
>> Best,
>> Daniel
>> > > Albert Saribekyan.
>> did it!!
>> > so help me..
>>      _______________
>> ___/
>> > GRASS homepage:
>>          http://grass.osgeo.**org <http://grass.osgeo.org>
>> (/bin/bash)
>> -c
>> > Start the GUI with:
>>          g.gui wxpython
>> > > > ______________________________**_________________
>> > http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121001/693c9abf/attachment.html>
