[GRASS-user] trouble with netCDF input arguments for r.in.gdal
    Kirk Wythers
    kirk.wythers at gmail.com
    Mon Oct  1 11:46:38 PDT 2012
Thanks Jennifer,
In my case I want all 1308 time dimensions… so I tried:
GRASS 6.4.1 (globe_30min):~ > r.in.gdal input=NETCDF:"~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc":PET output=cru_pet
but got the same error:
ERROR 4: `NETCDF:~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc:PET' does not exist in the file system,
and is not recognised as a supported dataset name.
I also tried single instead of double quotes, and give the full pathname instead of the ~/ for my home directory… still not working.
Also, if you specify PET as the variable of interest, do you still pull in the lat and lon data?
Thanks
On Oct 1, 2012, at 1:22 PM, Jennifer Boehnert <boehnert at ucar.edu> wrote:
> Hi Kirk,
> in your r.in.gdal syntax the time_bnds is the variable you want to read.  My guess would be the variable you want to read is pet.
> I would suggestion executing the following commands to read your file metadata before running the r.in.gdal.
> gdalinfo D:\data\projects\courses2012\IAI\data\B1_tas.nc
> This will  give you the variable names in your dataset.  In your case I see PET
> Then to find the dimensions on the variable of interest execute The syntax is your netCDF name : variable name
> gdalinfo NETCDF:D:\data\projects\courses2012\IAI\data\A2_tas.nc:tasC
> In my example the netCDF name is A2_tas.nc an the variable I want is tasC (temperature in degrees celsius).  My data has 10 temporal dimensions.
> You should put <netCDF Name>:PET
> Now that I know this I run the r.in.gdal
> r.in.gdal -o -e input=NETCDF: D:\data\projects\courses2012\IAI\data\A2_tas.nc:tasC output=SRESA2_tas
> In this example I am bringing in all times if you want specify just 1 time you can do so by using the BAND number.
> Jennifer
> On 10/1/2012 12:02 PM, Kirk Wythers wrote:
>> I am trying to read some netCDF data (from the CRU climate database) into grass. I am looking at the netcdf wiki page and       having a little trouble translating the instructions there to the output I am getting from "gdalinfo". Here is the
>> If I am trying to use syntax that looks something like:
>> r.in.gdal input=NETCDF:"sst.nc":time_bnds output=sst
>> I am getting the following error:
>> ERROR 4: `NETCDF:~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc:time_bnds' does not exist in the file system,
>> In my case, the PATH_TO_FILE is
>> However, I can't tell what to use in the place of ":time_bnds". Any ideas from the pasted text below of what my input argument should look like?
>> Thanks in advance,
>> Kirk
>> Here is output I am looking at from gdalinfo:
>> GRASS 6.4.1 (globe_30min):~ > gdalinfo ~/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc
>> ERROR 1: GDAL/GRASS57 driver was compiled against GDAL 1.8 but current library version is 1.9
>> Driver: netCDF/Network Common Data Format
>> Files: /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kirkw/Downloads/cru_ts_3_10.1901.2009.pet.dat.nc
>> Size is 720, 360
>> Coordinate System is `'
>> Origin = (-180.000000000000000,90.000000000000000)
>> Pixel Size = (0.500000000000000,-0.500000000000000)
>> Metadata:
>>   lat#long_name=latitude
>>   lat#units=degrees_north
>>   lon#long_name=longitude
>>   lon#units=degrees_east
>>   NC_GLOBAL#comment=Data restrictions: for academic research use only.Contact BADC for details
>>   NC_GLOBAL#contact=BADC <badc at rl.ac.uk>
>>   NC_GLOBAL#Conventions=CF-1.4
>>   NC_GLOBAL#history=Wed Feb  2 03:32:36 GMT 2011 : User badc : Program makegridsauto.for called by update.for
>>   NC_GLOBAL#institution=Data held at British Atmospheric Data Centre, RAL, UK.
>>   NC_GLOBAL#references=Information on the data is available at http://badc.nerc.ac.uk/data/cru/
>>   NC_GLOBAL#source=Run ID = 1102011219
>> Data generated by BADC from:
>> tmp.1009221824.dtb
>> dtr.1009221824.dtb
>> vap.1009221824.dtb
>> cld.1009221824.dtb
>>   NC_GLOBAL#title=CRU TS 3.10 Potential Evapotranspiration
>>   pet#_FillValue=9.969209968386869e+36
>>   pet#correlation_decay_distance=-999
>>   pet#long_name=potential evapotranspiration
>>   pet#missing_value=9.969209968386869e+36
>>   pet#units=mm
>>   time#calendar=gregorian
>>   time#long_name=time
>>   time#units=days since 1900-1-1
>> Corner Coordinates:
>> Upper Left  (-180.0000000,  90.0000000)
>> Lower Left  (-180.0000000, -90.0000000)
>> Upper Right ( 180.0000000,  90.0000000)
>> Lower Right ( 180.0000000, -90.0000000)
>> Center      (   0.0000000,   0.0000000)
>> Band 1 Block=720x1 Type=Float64, ColorInterp=Undefined
>>   NoData Value=9.96920996838686905e+36
>>   Metadata:
>>     NETCDF_DIMENSION_time=380
>>     NETCDF_time_units=days since 1900-1-1
>>     NETCDF_VARNAME=pet
>>     units=mm
>> Band 2 Block=720x1 Type=Float64, ColorInterp=Undefined
>>   Metadata:
>>     NETCDF_DIMENSION_time=410
>>     NETCDF_VARNAME=pet
>>     units=mm
>> Band 1308 Block=720x1 Type=Float64, ColorInterp=Undefined
>>   Metadata:
>>     NETCDF_DIMENSION_time=40161
>>     NETCDF_VARNAME=pet
>>     units=mm
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121001/9723272e/attachment.html>
