[GRASS-user] Rasterize polygons, multiple polygons per grid cell
Lars Dalby lars.dalby at gmail.com
Wed Oct 3 10:19:09 PDT 2012
Micha Silver wrote
>     v.out.ascii grid92_centroids out=grid92_centroids.txt
>     columns="cat,water_surf_area,...<other data>..."
>     # Check the ascii file to see column positions
This returned this error message on my system: v.out.ascii(44851) malloc:
*** error for object 0x102013dc0: incorrect checksum for freed object -
object was probably modified after being freed.
*** set a breakpoint in malloc_error_break to debug
Abort trap: 6
Unable to really figure what was going on here I started to look for
alternatives to solve this last step.
So I ended up skipping the export and simply doing:
v.to.rast input=VectorGrid output=glwdFinalRast use=attr
attrcolumn=water_surf_area
Where VectorGrid = grid92 in your example.
As far as I can see, this actually works!
Thank you very much for your help and for staying with me to the bitter end!
Best,
Lars
View this message in context: http://osgeo-org.1560.n6.nabble.com/Rasterize-polygons-multiple-polygons-per-grid-cell-tp5005264p5006172.html
Sent from the Grass - Users mailing list archive at Nabble.com.
