[GRASS-user] v.proj error: latitude or longitude exceeded limits
Rich Shepard rshepard at appl-ecosys.com
Fri Oct 5 11:12:59 PDT 2012
   Working with 6.5svn on Slackware and trying to reproject from a lat/lon
location to a project location. I can display the source map in the input
locatoin. This is the command log:
(Fri Oct  5 10:34:46 2012) v.proj --overwrite --verbose input=biosites
location=Nevada-LL mapset=PERMANENT Input Projection Parameters:  +proj=longlat
+no_defs
+a=6378137 +rf=298.257222101 +towgs84=0,0,0,0,0,0,0
Input Unit Factor: 1
Output Projection Parameters:  +proj=tmerc +lat_0=34.75
+lon_0=-115.5833333333333 +k=0.9999 +x_0=200000.00001016
+y_0=8000000.000010163 +no_defs +a=6378137 +rf=298.257222101
+towgs84=0.000,0.000,0.000
Output Unit Factor: 0.3048006096012192
WARNING: Vector map <biosites> already exists and will be overwritten
Reprojecting primitives:
WARNING: pj_transform() failed: latitude or longitude exceeded limits
ERROR: Error in pj_do_transform
(Fri Oct  5 10:34:46 2012) Command finished (0 sec)
   Where do I look for the source of this error?
TIA,
Rich
