[GRASS-user] v.in.ascii error: bad type reading source file
Helmut Kudrnovsky
hellik at web.de
Fri Oct 5 11:59:38 PDT 2012
>lat/lon
>SC-100|41.42188333|-115.99418333
>SC|42.30416667|-116.10600000
change the order of the coordinates
-115.99418333|41.42188333|SC-100
-116.10600000|42.30416667|SC
this is imported here in following location:
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/v-in-ascii-error-bad-type-reading-source-file-tp5006747p5006752.html
Sent from the Grass - Users mailing list archive at Nabble.com.
