[GRASS-user] v.proj error: latitude or longitude exceeded limits
Rich Shepard rshepard at appl-ecosys.com
Mon Oct 8 09:15:49 PDT 2012
On Sat, 6 Oct 2012, Markus Neteler wrote:
> Could you approximately set the same extent in the target (current)
> location and run g.region -b
> to print the maximum bounding box in lat/long on WGS84?
Markus,
   That does not appear to be the issue. I re-imported the source data into
location Nevada-LL, mapset PERMANENT. But, when I run v.proj I see a
really puzzling error. New thread.
Thanks,
Rich
