[GRASS-user] before v.vect.stats
Martin Album Ytre-Eide Martin.Album.Ytre-Eide at nrpa.no
Tue Oct 9 04:21:17 PDT 2012
Thanks!
I ment GRASS 7 ;)
g.extention extention=v.vect.stats
worked very well.
Martin
________________________________________
Fra: neteler.osgeo at gmail.com [neteler.osgeo at gmail.com] på vegne av Markus Neteler [neteler at osgeo.org]
Sendt: 8. oktober 2012 11:30
To: Martin Album Ytre-Eide
Cc: grass-user at lists.osgeo.org
Emne: Re: [GRASS-user] before v.vect.stats
On Mon, Oct 8, 2012 at 10:45 AM, Martin Album Ytre-Eide
<Martin.Album.Ytre-Eide at nrpa.no> wrote:
> Hello all.
> I see that in 6.7 there is a v.vect.stats function which I would like to
[you mean GRASS 7.scvn]
> use. However, I  am running 6.4.2 and don't want to install 6.7 (again).
You can install v.vect.stats via the extension manager in GRASS 6.
Markus
