[GRASS-user] Removing spurious features on vector map
    Alexander Muriy
    amuriy at gmail.com
    Tue Oct  9 13:47:54 PDT 2012
>    The attached image shows a vector map that has the attribute displayed
> along the boundaries of the various polygons. It should have that attribute
> only on the centroid.
>    When I try to delete those spurious features I cannot distinguish them
> from the boundary lines in the wxpython GUI digitizing window.
As I see, these features are "zero" areas with centroids. You can add
polygons areas to attribute table with <v.to.db> and then remove polygons
with the areas smaller than the chosen value (v.edit) or extract large
polygons (v.extract).
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121010/8612144a/attachment.html>
