[GRASS-user] Grass-GIS 7 first impressions
    Martin Landa
    landa.martin at gmail.com
    Fri Oct 19 08:46:31 PDT 2012
> Second, Python selection panels, for modules that should allow multiple selections, work badly.
well, try eg. `r.report` (which really defines "multiple" params).
> For example, g.copy. In the TCL-TK interface, I can use g.copy for multiple copies. OK, I usually use the command-line anyhow, but: If I attempt a second selection in the Python interface pane, it replaces the first selection instead of adding to it.
This is a special case, `g.copy` doesn't define "multiple" params, it
uses "from,to" syntax. Choose "from" from map selection widget and
then manually write ",<map_to>". In any case autogenerated GUI of the
modules like `g.copy` is not very usable. It would be cool to have
some fancy "map management" to allow more user-friendly coping,
renaming and removing maps. It's core functionality.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
