[GRASS-user] wingrass6 "d.mon png" and wingrass7 gui start failure in XP
Vaclav Petras wenzeslaus at gmail.com
Wed Oct 24 05:56:16 PDT 2012
On 24 October 2012 10:12, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 24, 2012 at 7:39 AM, 王德辉 <dehuiw at gig.ac.cn> wrote:
>> Hi,all
>> I find wingrass6svn could not use "d.mon start=PNG" and wingrass7svn can not
>> start in gui normally. the python.exe error of wingrass7 gui starting is
>> ""sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll".
> There is an open ticket for this:
> https://trac.osgeo.org/osgeo4w/ticket/305
> It would be very good if you could add a note in this ticket
> that it also affects you - to raise the importance. It is an
> OSGeo4W packaging issue and cannot be directly influences
> by the GRASS developers.
It seems that WinGRASS (WinGRASS-7.0.svn-r53520-384-Setup.exe) is affected too.
Message after starting GUI is:
 Can not find entry point sqlite3_rtree_geometry_callback of the
procedure in the dynamic link library sqlite3.dll.
Is there any solution or workaround for user, like to use older
version of WinGRASS or sqlite/spatialite?
Vaclav
