[GRASS-user] r.basin: specifying closing point by geographic coordinates
Helmut Kudrnovsky hellik at web.de
Wed Oct 24 09:10:36 PDT 2012
>By the way, i've never tested the script using lat/lon coordinates, but i
suppose that you can get >some of the parameters in a unit derived from
degrees, which is not correct,
once I've run the script in a lat/lon-wgs84-location, the results are odd.
>so you need to use metric coordinates in order to get a suitable result.
yes
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-basin-specifying-closing-point-by-geographic-coordinates-tp5010864p5010896.html
Sent from the Grass - Users mailing list archive at Nabble.com.
