[GRASS-user] r.watershed : "minimum size of exterior watershed	basin"
    laurent celati
    lcelati at latitude-geosystems.com
    Thu Oct 25 04:11:56 PDT 2012
Hello,
Thanks for your reply. Yesterday i tested Grass via SextanteFORQgis. There
was a bog during the process and i had a error message.
This morning i have tested Grass via Qgis and it's works well. I have 2
questions :
1/With Grass r.watershed i have to enter this following parameter : "minimum
size of exterior watershed basin" (without unit value). What criteria
determines the value to be enter? How to know this value ?
In my case, i 'm using SRTM 90m as DEM raster input.
2/According to you, what is the better tool  between r.watershed or Taudem
"StreamReach and watershed" ?
Thank you in advance.
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-watershed-minimum-size-of-exterior-watershed-basin-tp5011178.html
Sent from the Grass - Users mailing list archive at Nabble.com.
