[GRASS-user] urgently!!!
Johannes Radinger johannesradinger at gmail.com
Fri Oct 26 03:18:53 PDT 2012
You could try to start GRASS with the GUI. Then you'll see
that your mapset you want to start is greyed out. Anyway
if you select it and click start GRASS will ask you if you
want to remove the GISLOCK.
Unfortunately I don't know how to remove the GIS lock
from the Terminal (but there must be a way other GIS users
know)
/j
On Fri, Oct 26, 2012 at 11:29 AM, Albert Saribekyan
<albertsaribekyan at rambler.ru> wrote:
> Albert Saribekyan.
> during grass session my inet connection failed and now it is impossible to
> start grass
> [albert at ce ~]$ /localuser/soft/grass7_inst/bin/grass70 -text
> /home/albert/grassdata/bol/PERMANENT/
> Cleaning up temporary files...
> Starting GRASS GIS...
> albert is currently running GRASS in selected mapset (file
> /home/albert/grassdata/bol/PERMANENT/.gislock found). Concurrent use not
> allowed.
> [albert at ce ~]$
> I am waiting for Your answer!!
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
