[GRASS-user] status of launchpad Ubuntu builds [WAS: Re: how to install GRASS binaries of weekly snapshot on ubuntu12.04?]
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sun Oct 28 16:53:08 PDT 2012
Hi Tim,
I was having the same error in openSUSE OBS about gui/wxpython and it is
now fixed in svn (branch_64).
I see that there is a direct mirror from subversion to bazaar in LP.
This should trigger a build on every new commit through the recipe, but
is this really needed? Perhaps this should be done weekly.
I had a look at the debian files in case I could create a grass7 (like
the one for openSUSE) but the rule file is very complicated. Is it due
to lintian checks?
Angelos
On 10/29/2012 12:02 AM, Tim Michelsen wrote:
>> Sidenote: I really hope that one day Ubuntu launchpad will deliver
>> GRASS binaries...
> Since all code is well imported from SVN to LP:
> https://code.launchpad.net/~grass/grass/releasebranch_6_4
> It is /*only/* an issue of updating the debian files:
> https://code.launchpad.net/~grass/grass/grass64_release_debian
> All members of the GRASS GIS team can do this:
> https://launchpad.net/~grass/+members
> once this is automatically taken up by the recipe:
> https://code.launchpad.net/~grass/+recipe/grass64
> Last, I deactivated it as it was continuously failing (see below).
> Since 2 years I am not working with GRASS on day2day basis.
> Thus, there's no time and current need.
> I would be grateful if someone could assist and co-maintain the GRASS
> project on Launchpad.
> I am willing to assist in setting everything up.
> Regards.
> Started compilation: Mon Oct 22 02:44:24 UTC 2012
> Errors in:
> /build/buildd/grass-6.4.2+0ubuntu1+21696~oneiric1/gui/wxpython
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Mon Oct 22 02:55:33 UTC 2012
> make[1]: *** [default] Error 1
> make[1]: Leaving directory
> `/build/buildd/grass-6.4.2+0ubuntu1+21696~oneiric1'
> make: *** [build-stamp] Error 2
> dpkg-buildpackage: error: debian/rules build gave error exit status 2
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
