[GRASS-user] use of grass 6.4 and 7 on the same location/mapsets
Nick Cahill
ndcahill at wisc.edu
Mon Oct 29 04:24:24 PDT 2012
I found that once I'd converted my vectors to Grass 7, I couldn't go back. I ended up going back to 6.4 and having to restore old vectors from a backup. It was a pain. Is there an easy way to convert back?
Thanks,
Nick Cahill
On Oct 29, 2012, at 11:59 AM, Maris Nartiss wrote:
> If they are not accessed at a same time, then only problem will be
> with vector data. GRASS 7 uses a bit different vector data storage
> format and thus vector data can be used (displayed) only after a
> v.build run. It's a bit annoying and I don't know if it can introduce
> any problems (I mean when going G7->G6 vectors), still I haven't
> observed any.
> In conclusion - for raster - doesn't matter; vectors - better stick to
> one version.
> Maris.
> 2012/10/28 Laura Poggio <laura.poggio at gmail.com>:
>> Dear list,
>> are any problems in having mapsets accessed from different version of GRASS
>> (6.4.2. and 7)?
>> Thank you
>> Laura
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
