[GRASS-user] Is "i.cluster" an implementation of the ISODATA algorithm?
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Oct 31 02:36:10 PDT 2012
Sorry, I forgot to CC Christos :)
On 10/31/2012 11:32 AM, Angelos Tzotsos wrote:
> Hi all,
> This is an ISODATA implementation in C, written under GPL by Christos
> Iossifidis, a colleague of mine at NTUA.
> Would anyone be interested porting it to GRASS?
> http://users.ntua.gr/chiossif/Free_As_Freedom_Software/isodata.c
> Cheers,
> Angelos
> On 10/31/2012 01:48 AM, Nikos Alexandris wrote:
>> NikosA:
>>>>>> I wonder why the term ISODATA [2] is not to be traced anywhere in
>>>>>> the
>>>>>> GRASS manuals, nor in the GRASS book (3rd ed.).  Can someone confirm
>>>>>> that i.cluster is an(other) implementation of the ISODATA clustering
>>>>>> algorithm?
>> MarkusN:
>>>>> I search in my inbox and found some earlier discussion with the
>>>>> Subject: "Re: [GRASS-user] Re: algorithm used in i.cluster", see
>>>>> below.
>>>>> PS: Still we need a text snippet to improve the manual...
>>>> Things to keep in mind from the archived discussions (below):
>>>> - the ISODATA algorithm (Ball and Hall, 1967) is a common
>>>> modification of
>>>> the K-means algorithm
>>>> - the algorithm implemented in the "i.cluster" module involves
>>>> merging of
>>>> classes (I_cluster_merge) though no splitting function seems to be
>>>> implemented
>> Moritz:
>>> To add: i.cluster output is also not equivalent to ISODATA in so far as
>>> it does not classify all pixels, but only creates signature files for
>>> the classes. Classification is then done by i.maxlik which is not
>>> equivalent to ISODATA. It might be an interesting addition to i.cluster
>>> to work with all pixels (not only a subset) and to create an output
>>> assigning each pixel to a given class which would be close (but not
>>> equal) to ISODATA output.
>> Moritz,
>> please correct me if I am wrong.  I feel that the above sentences draw
>> actually an unnecessary confusion.
>> The first step is to cluster pixels according to their (similar,
>> spectral)
>> properties.  The second step is to classify the clusters, meaning
>> labeling of
>> the resulted clusters.   So, I don't see were confusions might arise,
>> apart
>> from the question whether "i.cluster" is an exact implementation of the
>> ISODATA algorithm or not.
>> - ISODATA is a clustering algorithm, not a classification algorithm
>> per se --
>> skimming through Richards book (1999) [1], pages 182, 189, 225. And the
>> "i.cluster" module might not be identical to the ISODATA clustering
>> algorithm,
>> yet, it performs clustering. So, both do the same job, most likely in
>> a more
>> or less similar way.
>> -  "i.maxlik" performs the classification of the clusters, which is
>> not a
>> clustering process. Thus, the module can/should not be identical to the
>> ISODATA clustering algorithm.  I might have missed something
>> (skimming through
>> the manuals), but I didn't read anywhere that "i.maxlik" is performing
>> clustering.
>> Your attention to details is highly appreciated.
>> Thanks, Nikos
>> [1] @BOOK{Richards1999,
>>    title = {{{R}emote {S}ensing {D}igital {I}mage {A}nalysis. {A}n
>> {I}ntroduction,
>>     3rd revised and enlarged edition.: xxi + 363 pp.}},
>>    publisher = {Berlin, Heidelberg, New York, London, Paris, Tokyo,
>> Hong Kong:
>> Springer-Verlag.},
>>    year = {1999},
>>    author = {JA Richards and X Jia},
>>    pages = {363},
>>    edition = {3},
>>    note = {Hard cover},
>>    isbn = {3-540-64860-7}
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
