[GRASS-user] Unable to locate Curses Includes
Rebecca Bennett
rabennett at ymail.com
Wed Oct 31 07:56:51 PDT 2012
Great thanks Madi - I'd used that approach for the two earlier errors when running this command but couldn't find a package relating to curses in my search for unintalled packages (probably due to the curses but being surrounded by other letters!)
Incedentally non-of the add-ons are working through the gui - I know this is a freqently reported problem to which the only guaranteed solution (after scouring the mailing list and trying solutions posted here http://planetflux.adamwilson.us/2012/02/installing-grass-extensions-on-ubuntu.html and http://comments.gmane.org/gmane.comp.gis.grass.user/43974) appears to be to compile from source.
...I wanted large file support anyway so I was just being lazy to only use the Ubuntu:GIS repository version :)
cheers!
Rebecca
>________________________________
> From: Margherita Di Leo <diregola at gmail.com>
>To: Rebecca Bennett <rabennett at ymail.com>
>Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>Sent: Wednesday, 31 October 2012, 10:46
>Subject: Re: [GRASS-user] Unable to locate Curses Includes
>Dear Rebecca,
>On Wed, Oct 31, 2012 at 3:30 PM, Rebecca Bennett <rabennett at ymail.com> wrote:
>Dear Grass Users,
>>Trying to compile 6.4.3 from source on Ubuntu 12.04 in order to get at the add-ons which are not working in my prepackaged install.
>Which add-on is not working?
>>Following these instructions (http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu) I check out the release_20121024_grass_6_4_3RC1 get as far as
>>./configure \
>>but get the following error:
>>checking for long long int... yes
>>checking for W11... no
>>checking for X... no
>>checking whether to use Curses... yes
>>checking for curses.h... no
>>configure: error: *** Unable to locate curses includes.
>>Any suggestions / ideas welcome!
>I think you miss libncurses5-dev.
>In general, when you get an error like this, you can do the search yourself here: http://packages.ubuntu.com/
>You have to search "contents of packages" and specify your version/distribution.
>Hope this helps,
>madi
>Margherita DI LEO
>Postdoctoral Researcher
>European Commission - DG JRC
>Forest Resources and Climate
>I-21020 Ispra (VA) - Italy - TP 261
>Tel. +39 0332 78 3600
>margherita.di-leo at jrc.ec.europa.eu
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121031/a78f07b4/attachment.html>
