[GRASS-user] [off-topic] Problem in compile rgdal on Lion
Marcello Benigno benigno.marcello at gmail.com
Wed Oct 31 16:41:45 PDT 2012
I can't install rgdal library on Lion, tried this:
R CMD INSTALL --configure-args='--with-gdal-config=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config
--with-proj-include=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-lib=/Library/Frameworks/PROJ.framework/unix/lib'
/Users/marcello/Downloads/rgdal_0.7-20.tar.gz
* installing to library
‘/usr/local/Cellar/r/2.15.2/R.framework/Versions/2.15/Resources/library’
* installing *source* package ‘rgdal’ ...
** package ‘rgdal’ successfully unpacked and MD5 sums checked
configure: gdal-config: /Library/Frameworks/GDAL.framework/unix/bin/gdal-config
checking gdal-config usability... yes
configure: GDAL: 1.9.1
checking GDAL version > 1.5.4... yes
checking for gcc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... rm: conftest.dSYM: is a directory
yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking gdal.h usability... yes
checking gdal.h presence... yes
checking for gdal.h... yes
checking gdal: linking with --libs only... no
checking gdal: linking with --libs and --dep-libs... no
clang: warning: treating 'c' input as 'c++' when in C++ mode, this
behavior is deprecated
gdal_test.c:5:1: error: C++ requires a type specifier for all declarations
main() {
1 error generated.
main() {
1 error generated.
configure: Install failure: compilation and/or linkage problems.
configure: error: GDALAllRegister not found in libgdal.
ERROR: configuration failed for package ‘rgdal’
* removing ‘/usr/local/Cellar/r/2.15.2/R.framework/Versions/2.15/Resources/library/rgdal’
Any Ideas?
Thanks in advance.
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121031/f59383c3/attachment.html>
