[GRASS-user] New AddOns for Analyzing landscape connectivity based on graph-theory - the r.connectivity.*-toolchain
SBL Stefan.Blumentrath at nina.no
Fri Sep 14 01:06:09 PDT 2012
Hi
I did use the g.extension-manager through the wxGUI. And both, scripts and
bat-files are in the addon-folder (within my Windows user profile). The GUI
of the addons starts and I can fill in the parameters. But after ran the
command (clicked the Run button) I get the message mentioned.
I checked if the scripts work in general by copying the scripts manually
into the script folder and the bat-files into the bin folder (after
adjusting the path to %GISBASE%)... After I did that the scripts worked
(though only through command line, through the wxGUI v.extract did not run
successful).
Probably, the addon-path (spaces in the path to my Windows user profile...)
causes trouble?
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/New-AddOns-for-Analyzing-landscape-connectivity-based-on-graph-theory-the-r-connectivity-toolchain-tp5000351p5001880.html
Sent from the Grass - Users mailing list archive at Nabble.com.
