[GRASS-user] Using r.out.kml and scripts in Windows Binary- error
Helmut Kudrnovsky
hellik at web.de
Fri Sep 14 03:05:46 PDT 2012
>> I purposely left the g.extension(.sh) installed in the Windows build as
>> theoretically & fundamentally it should work if the user has a full
>> compiler
>> and build environment for grass set up. For those people, and in the hope
>> that someone might be able to make it work better someday, it remains.
>I tend to disagree - most (99%?) of our Windows users will not have
>a compiler environment installed. Just browse the archives how many
>failed into the trap of using g.extension on Windows on command line...
>Yes, this is the minimum we can do.
>Or just get it done automatically: if no gcc present, switch to the
>Python script.
AFAIK the standalone wingrass-installer has an build/compiler environment
inside, because it's based upon the osgeo4w-build-stack; but there are
whitespace-in-path-issues related to gcc etc.
"normal" osgeo4w-wingrass-users probably hasn't installed the build-deps by
default.
>This should be urgently fixed.
+1
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Using-r-out-kml-and-scripts-in-Windows-Binary-error-tp5001496p5001913.html
Sent from the Grass - Users mailing list archive at Nabble.com.
