[GRASS-user] problem installing Grass 7 in RHEL6
Mauricio Zambrano-Bigiarini
hzambran.newsgroups at gmail.com
Fri Sep 14 05:47:25 PDT 2012
Thank you very much Soeren and Markus for your help.
Now I have Grass 7 running on RHEL6 :)
Just in case this be useful for somebody else. The final part of the
procedure I used for getting the installation done was:
4) Following 'http://grass.osgeo.org/wiki/Compile_and_Install#CentOS',
in the file:
grass_trunk/include/Make/Platform.make
I manually add the path to the python include:
PYTHONINC = -I/usr/include/python2.6 # not python2.4 !!
5) After installing 'python-dateutil' package (I think it would be
useful for other users to add it into the dependencies listed in
''http://grass.osgeo.org/wiki/Compile_and_Install'' ), I only got one
error:
Errors in:
/dataMZB/src/grass_trunk/scripts/v.krige
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Sep 14 13:47:54 CEST 2012
make: *** [default] Error 1
So, I run 'make' on the directory:
6) Then, I change to the original trunk directory and run 'make'
again, and I didn't get any error. The last lines of the output were:
GRASS GIS compilation log
Started compilation: Fri Sep 14 14:33:51 CEST 2012
Errors in:
No errors detected.
7) Finally, I run:
$ sudo make install
and Grass 7 is finally running.
All the best,
Mauricio
Water Resources Unit
Institute for Environment and Sustainability
Joint Research Centre, European Commission
webinfo : http://floods.jrc.ec.europa.eu/
DISCLAIMER:
"The views expressed are purely those of the writer
and may not in any circumstances be regarded as
stating an official position of the European Commission"
Linux user #454569 -- Ubuntu user #17469
"If you can dream it, you can do it" . (Walt Disney)
http://c2.com/cgi/wiki?HowToAskQuestionsTheSmartWay
2012/9/14 Markus Metz <markus.metz.giswork at gmail.com>:
> On Fri, Sep 14, 2012 at 9:17 AM, Mauricio Zambrano-Bigiarini
> <hzambran.newsgroups at gmail.com> wrote:
>> Dear List,
>> I already managed to compile and install Grass 7 in Ubuntu 12.04, but
>> now I want to try it at work.
>> I'm trying to install Grass 7 on Red Hat Enterprise Linux 6, but I got
>> stuck during 'make', and I would like to ask your advice for solving
>> the issue.
> According to the error log, most of GRASS was compiled successfully
> and can be used without problems. The t.* commands require an
> additional package python-dateutil which you can install on RHEL 6
> with
> yum install python-dateutil
> After that package has been installed, the t.* modules should compile
> successfully.
> HTH,
> Markus M
>> My machine:
>> $ uname -r
>> 2.6.32-279.5.2.el6.x86_64
>> Following the instructions given on
>> 'http://grass.osgeo.org/wiki/Compile_and_Install', I tried:
>> 1) Installing all dependencies:
>> sudo yum install flex bison zlib-devel tcl-devel tk-devel gcc-c++
>> swig gettext \
>> libtiff-devel libpng-devel sqlite-devel \
>> mesa-libGL-devel mesa-libGLU-devel mesa-libGLw-devel \
>> mesa-libOSMesa-devel libXmu-devel python-devel gtk2-devel\
>> ncurses-devel postgresql-devel
>> 2) configure:
>> CFLAGS="-g -Wall" ./configure \
>> --with-cxx \
>> --with-sqlite \
>> --with-postgres \
>> --with-freetype \
>> --with-freetype-includes=/usr/include/freetype2 \
>> --with-motif \
>> --with-proj-share=/usr/share/proj
>> which gave as output:
>> GRASS is now configured for: x86_64-unknown-linux-gnu
>> Source directory: /dataMZB/src/grass_trunk
>> Build directory: /dataMZB/src/grass_trunk
>> Installation directory: ${prefix}/grass-7.0.svn
>> Startup script in directory: ${exec_prefix}/bin
>> C compiler: gcc -g -O2
>> C++ compiler: c++ -g -O2
>> Building shared libraries: yes
>> OpenGL platform: X11
>> MacOSX application: no
>> MacOSX architectures:
>> MacOSX SDK:
>> Tcl/Tk NVIZ: yes
>> BLAS support: no
>> C++ support: yes
>> Cairo support: yes
>> DWG support: no
>> FFMPEG support: no
>> FFTW support: no
>> FreeType support: yes
>> GDAL support: yes
>> NETCDF support: no
>> GEOS support: no
>> LAPACK support: no
>> Large File support (LFS): yes
>> libLAS support: no
>> MySQL support: no
>> NLS support: yes
>> ODBC support: no
>> OGR support: yes
>> OpenGL support: yes
>> OpenMP support: no
>> PNG support: yes
>> POSIX thread support: yes
>> PostgreSQL support: yes
>> Readline support: no
>> Regex support: yes
>> SQLite support: yes
>> TIFF support: yes
>> Tcl/Tk support: yes
>> wxWidgets support: yes
>> X11 support: yes
>> 3) $ make
>> and the the errors I got at the end of 'make' were:
>> /usr/bin/install -c -m 644 REQUIREMENTS.html
>> /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/REQUIREMENTS.html
>> /usr/bin/install -c -m 644 GPL.TXT
>> /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/GPL.TXT
>> /usr/bin/install -c -m 644 contributors.csv
>> /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/contributors.csv
>> /usr/bin/install -c -m 644 contributors_extra.csv
>> /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/contributors_extra.csv
>> /usr/bin/install -c -m 644 translators.csv
>> /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/translators.csv
>> make[1]: Leaving directory `/dataMZB/src/grass_trunk'
>> make manifests
>> make[1]: Entering directory `/dataMZB/src/grass_trunk'
>> make[1]: Nothing to be done for `manifests'.
>> Started compilation: Thu Sep 13 17:03:08 CEST 2012
>> Errors in:
>> /dataMZB/src/grass_trunk/temporal/t.create
>> /dataMZB/src/grass_trunk/temporal/t.support
>> /dataMZB/src/grass_trunk/temporal/t.topology
>> /dataMZB/src/grass_trunk/temporal/t.list
>> /dataMZB/src/grass_trunk/temporal/t.info
>> /dataMZB/src/grass_trunk/temporal/t.remove
>> /dataMZB/src/grass_trunk/temporal/t.sample
>> /dataMZB/src/grass_trunk/temporal/t.register
>> /dataMZB/src/grass_trunk/temporal/t.unregister
>> /dataMZB/src/grass_trunk/temporal/t.rast.aggregate
>> /dataMZB/src/grass_trunk/temporal/t.rast.aggregate.ds
>> /dataMZB/src/grass_trunk/temporal/t.rast.to.rast3
>> /dataMZB/src/grass_trunk/temporal/t.rast.univar
>> /dataMZB/src/grass_trunk/temporal/t.rast.list
>> /dataMZB/src/grass_trunk/temporal/t.rast.mapcalc
>> /dataMZB/src/grass_trunk/temporal/t.rast.series
>> /dataMZB/src/grass_trunk/temporal/t.rast.export
>> /dataMZB/src/grass_trunk/temporal/t.rast.out.vtk
>> /dataMZB/src/grass_trunk/temporal/t.rast.import
>> /dataMZB/src/grass_trunk/temporal/t.rast.gapfill
>> /dataMZB/src/grass_trunk/temporal/t.rast.extract
>> /dataMZB/src/grass_trunk/temporal/t.rast3d.list
>> /dataMZB/src/grass_trunk/temporal/t.rast3d.extract
>> /dataMZB/src/grass_trunk/temporal/t.rast3d.mapcalc
>> /dataMZB/src/grass_trunk/temporal/t.rast3d.univar
>> /dataMZB/src/grass_trunk/temporal/t.vect.list
>> /dataMZB/src/grass_trunk/temporal/t.vect.db.select
>> /dataMZB/src/grass_trunk/temporal/t.vect.export
>> /dataMZB/src/grass_trunk/temporal/t.vect.extract
>> /dataMZB/src/grass_trunk/temporal/t.vect.import
>> /dataMZB/src/grass_trunk/temporal/t.vect.what.strds
>> /dataMZB/src/grass_trunk/temporal/t.vect.observe.strds
>> /dataMZB/src/grass_trunk/temporal/t.vect.univar
>> Finished compilation: Thu Sep 13 17:28:47 CEST 2012
>> Following the instructions, I did make within the first directory
>> (/dataMZB/src/grass_trunk/scripts/v.krige) and I did not get any
>> error.
>> Then, I went to the second directory
>> (/dataMZB/src/grass_trunk/temporal/t.create), and I got the following
>> error message:
>> $ make
>> if [ "/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create"
>> != "" ] ; then GISRC=/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
>> GISBASE=/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu
>> PATH="/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:$PATH"
>> PYTHONPATH="/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
>> LD_LIBRARY_PATH="/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:"
>> LC_ALL=C /dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create
>> --html-description < /dev/null | grep -v '</body>\|</html>' >
>> t.create.tmp.html ; fi
>> Traceback (most recent call last):
>> File "/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/scripts/t.create",
>> line 59, in <module>
>> import grass.temporal as tgis
>> File "/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/__init__.py",
>> line 7, in <module>
>> from abstract_map_dataset import *
>> File "/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/abstract_map_dataset.py",
>> line 22, in <module>
>> from datetime_math import *
>> File "/dataMZB/src/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/datetime_math.py",
>> line 17, in <module>
>> from dateutil import parser
>> ImportError: No module named dateutil
>> make: *** [t.create.tmp.html] Error 1
>> rm t.create.tmp.html
>> Do you have any advice for solving this problem and get Grass 7
>> installed on RHEL 6 ?
>> Thanks in advance,
>> DISCLAIMER:
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
