[GRASS-user] problem installing Grass 7 in RHEL6
Mauricio Zambrano-Bigiarini
hzambran.newsgroups at gmail.com
Fri Sep 14 07:55:42 PDT 2012
2012/9/14 Margherita Di Leo <diregola at gmail.com>:
> On Fri, Sep 14, 2012 at 4:27 PM, Mauricio Zambrano-Bigiarini
> <hzambran.newsgroups at gmail.com> wrote:
>> Hi Margherita,
>> > Hi,
>> > On Fri, Sep 14, 2012 at 3:26 PM, Mauricio Zambrano-Bigiarini
>> >> 2012/9/14 Markus Neteler <neteler at osgeo.org>:
>> >> > On Fri, Sep 14, 2012 at 2:47 PM, Mauricio Zambrano-Bigiarini
>> >> >> Errors in:
>> >> >> /dataMZB/src/grass_trunk/scripts/v.krige
>> >> >> So, I run 'make' on the directory:
>> >> > There appears to big in the Makefile of v.krige.
>> >> > I get the same problem: success only at the second run of "make".
>> >> That is strange for me, because in Ubuntu 12.04 (I'm almost sure that)
>> >> I only run "make" once ....
>> > I confirm i don't need to run 'make' in this folder either, I'm on Red
>> > Hat.
>> 32 or 64 bits ?
> 64
That is weird for me.
With the same OS and architecture, you didn't have to run 'make' on
the directory:
Probably somebody may be able to explain that ...
Cheers,
Mauricio
