[GRASS-user] problem with disk space. Raster data
Antonio Rodríguez
antonio.raju at gmail.com
Sun Sep 16 08:56:01 PDT 2012
I'm performing a couple of treatments over a specific region and my
problems arise when I deal with UTM projection in contrast with
Lat/Lon projection.
1) I import my raster data (Aster Dem) using the properties of the
georreferenced GeoTiff image with wgs84 datum and lat/lon projection
2) I perform, for example, a r.shaded.relief over the data and
everything runs fine. I get my new file in a decent time
The problem arise when after creating a newlocation with the
corresponding lat/lon coordinates transformed to UTM ones I try to
follow the steps above.
1) The import of the new data is OK and I can see the image with no
problem, but...
2) performing the r.shaded.relief process I got a full hard disk
(100%) and an overnight run for the computer
Using r.info for both original data sources I get:
A) Lat/Lon Proj
Type of Map: raster Number of Categories: 5988 |
| Data Type: CELL |
| Rows: 3601 |
| Columns: 3601 |
| Total Cells: 12967201 |
| Projection: Latitud - Longitud. |
| N: 7:59:59.5S S: 9:00:00.5S Res: 0:00:01 |
| E: 75:59:59.5W W: 77:00:00.5W Res: 0:00:01 |
| Range of data: min = -580 max = 5988
B) UTM Proj
Type of Map: raster Number of Categories: 6744 |
| Data Type: CELL |
| Rows: 2965 |
| Columns: 2282 |
| Total Cells: 6766130 |
| Projection: UTM (zone -18) |
| N: 9055864.24489094 S: 8964905.38350331 Res: 30.67752492 |
| E: 244988.11769175 W: 174982.00582445 Res: 30.67752492 |
| Range of data: min = 0 max = 6744
As you can notice, the UTM region is even smaller tha the Lat/Lon one. Any idea?
Thanks!
Antonio
PD: I'm running a Debian Intel machine with 2GB of RAM
