[GRASS-user] r.li.setup in GRASS 7
ahmadou dicko dicko.ahmadou at gmail.com
Mon Sep 17 16:15:11 PDT 2012
Thank's a lot Markus.
I tried it but I'm not able to create a good conf file (compare my
movwindow3_new produced by r.li.setup.py and movwindow3 produced in GRASS
6.4 long time ago)
When I tried r.li.patchdensity (or another r.li.*) I end up with this error
(I tried to reproduce one  example of the GRASS 2008 book on p.154)
r.li.patchnum input=forest1996 at user1 config=movwindow3_new
output=forest_p_num3_new
ERROR: Illegal configuration file (sample area)
I don't have enough skills in this area to help so I'll have to wait a few
week (when this addon will be finished and added) and use R for the time
being.
Thank's again for your time
On Mon, Sep 17, 2012 at 4:18 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Sep 17, 2012 at 6:10 PM, ahmadou dicko <dicko.ahmadou at gmail.com>
> wrote:
> > Hi Grass User,
> > I'm using GRASS 7 ( revision 53178) and I would like to compute some
> > landscape metrics (mean patchs size, density....).
> > But there's no r.li.setup in GRASS 7, so I wan't to know if there's a
> > workaround or another way to use r.li or even r.le in GRASS 7 ?
> Luca Delucchi is working on it:
> http://trac.osgeo.org/grass/browser/sandbox/lucadelu/r.li.setup.py
> If you want to trey, at page bottom:
>  - Download in other formats:
>    --> Original Format
> However, a few things are still missing which shall be added within
> a week or so.
> Markus
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120917/219bdf3f/attachment.html>
Une pi?ce jointe autre que texte a ?t? nettoy?e...
Nom: movwindow3_new
Type: application/octet-stream
Taille: 21 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120917/219bdf3f/attachment.obj>
Nom: movwindow3
Taille: 93 octets
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120917/219bdf3f/attachment-0001.obj>
