[GRASS-user] Rasterize polygons, multiple polygons per grid cell
Lars Dalby lars.dalby at gmail.com
Sat Sep 29 15:32:02 PDT 2012
Micha Silver wrote
>     Can you copy/paste your exact command? I think there should not be
>     any space between 'coor' and '='.
Sure, but as I run them from R, they look a bit different that when run from
command line GRASS.
execGRASS('v.mkgrid', parameters = list(map = 'VectorGrid', position =
'coor', coor = '-6358820,-17367529', grid = '142,360', box =
'96486.28169014, 96486.28055556'))
What happens here is that the list() command will make a list with 5 slots
in this case. It looks like this:
$map
[1] "VectorGrid"
$position
[1] "coor"
$coor
[1] "-6358820,-17367529"
$grid
[1] "142,360"
$box
[1] "96486.28169014, 96486.28055556"
So it will not make any difference to what is being send to GRASS if I have
blank spaces between '=' and the values. R ignores these when making the
list. I am afraid that the problem doesn't lie here.
Do you think it could be related to the GRASS version I am running? (I am
using 7.0)
-Lars
View this message in context: http://osgeo-org.1560.n6.nabble.com/Rasterize-polygons-multiple-polygons-per-grid-cell-tp5005264p5005361.html
Sent from the Grass - Users mailing list archive at Nabble.com.
